Thinking about building a M274 Mule clone
   / Thinking about building a M274 Mule clone #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
   / Thinking about building a M274 Mule clone #2
Yes, I've thought about it.
Basic idea: Build a suspensionless frame using 2 narrow Jeep 5.38/1 front axles and low only transfer case. Weld the differentials. No decision on engine. That would be about 10 inches wider than the Mule, unless you replaced the long axle side with a short axle tube and shaft.
Bruce
That's pretty much where I was too. The getcha is that I really want to use two front axles so I believe the back one will be turning the wrong way. Was thinking of using hydraulics to steer the axles. Would prefer to have a single steer cylinder with a drag link connecting the other axle, but because the axle has been flipped around, I believe the link would need to cross the body. Power would be via hydraulics, but I'm not sure how to connect the motor to the transmission or transfer case.
   / Thinking about building a M274 Mule clone #4
Having each end steered independently would be ideal. You could have normal turns, very sharp turn, or move diagonally.
Most of my daydreaming designs were before car independent suspension powered rear and front ends were readily available. There is now probably something out there that would work better than old Jeep axles.
When you put a front axle in the rear, pinion shaft facing forward, the drive rotation is opposite, so it will still go forward. For example, if in front, driveshaft turning clockwise, top of wheel moves away from driveshaft. Turn it around and put it in rear. Driveshaft now turns counterclockwise, top of wheel moves toward driveshaft.
Bruce
   / Thinking about building a M274 Mule clone #5
not exactly what your use for it would be, but a lawn tractor cut in halv and widened could be a good starting point,
If one could find a old 4 wheeler that could be used for platform, (the engine and transmission) small light weight.
even a small front wheel drive car, stripped down (may want to reposition the steering wheel, (what I am thinking is to just use the front engine mount and build the rear part of the frame kind of a set up like the old ford econoline pickup
for a true 4x4, even some thing like a SUZUKI 4x4 there may be other makes of small suv/pickups one could use for a platform,
a rolled one could be an exelent place to start,
   / Thinking about building a M274 Mule clone #6
One note, IIRC this will have the gear in the pumpkin turning in "reverse" all the time (reverse is weaker than foward as it uses the "coast" side of the gears). Not a big deal in a low speed offroad application, but problematic in a high speed/onroad application.
Aaron Z
   / Thinking about building a M274 Mule clone #7
wrong thread sorry,
   / Thinking about building a M274 Mule clone #8
   / Thinking about building a M274 Mule clone #9
While not geared as low Suzuki samurai axles using 2 short side shafts gets you a medium duty axle that is 48 inches (I think) outside wheel mounting flange to flange on both steering axles and rear non steering axle. Lockers are available as well as lower gears The transfer cases are small light and divorced so any motor trans option will work low range gear options are 2.? stock 4.16 aftermarket up to 6.5 low
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2017 CATERPILLAR 279D SKID STEER (A51246)
2017 CATERPILLAR...
