Think this will hold up
   / Think this will hold up #1
escavader
Veteran Member
western maine
bx-23 ,
For wood splitter wedge.they are very large chipper knifes.i had them sharpened and was gonna weld two togeather3/4 inch thick
What rod ?
Sent from my iPhone using TractorByNet
   / Think this will hold up #2
I doubt it especially since they have slots cut in them. They are hardened steel and are brittle. I did make a backhoe scraper and used the blade from a chipper. It has held up, but doesn't have a fraction of the force of a wood splitter. image-3350328379.jpg
   / Think this will hold up #3
I think the success/failure is totally dependent on your splitter strength??
As for welding them together, I'd use 7018 and crank up the heat.
   / Think this will hold up #4
Preheat and post heat are important preheat till its too hot to touch with gloved hands for more than a few seconds then weld it. After bury it in dry sand wrapping in fire blankets works too leave it overnight at least.
   / Think this will hold up #6
Exactly why I told him to pre heat and post heat.
   / Think this will hold up #7
Stainless rod works very well on hardened steel. It's very ductile and resistant to cracking. I use 308L because that's what I have, but apparently 309 is made for this.
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
