Think I need a better tractor - B6000 with slasher puts front wheels off the ground
   / Think I need a better tractor - B6000 with slasher puts front wheels off the ground #1
greyman56
Veteran, QLD, Australia
Mahindra 4025 4x4, Kubota B6000 (Zen-Noh), John Deere L100
Hi All, this is my first post here so I hope I have it in the right forum. Apologies to those that use feet and pounds, we use metric here in the land downunder. :)
We are on a 45 acre (18ha) property that we purchased a couple of years ago and are in the process of reviving after plenty of neglect.
What I want to achieve:-
I have a Mango orchid with 50 trees planted in 4 rows running down a slope of nearly 1 in 4 (30m fall over just under 120m measured horizontally). The orchid is grassed with a clumpy tropical grass (Setaria), some smaller grasses, and it is a bit sparse in places exposing the shale/clay based soil.
I can slash between the rows with my Mahindra 40HP 4x4 tractor with ROPS and SOPS, but cannot easily get under and around the trees without damaging the tree branches, which is a problem especially during the flowering time. I am reasonably proficient on the 40HP as I have done 180 hours slashing all sorts of terrain with it and feel quite comfortable with its operation.
So I would like a compact tractor with either a mid mounted mower, or a small slasher (around 1m or 3ft), to get in and around the tree trunks.
What I have done so far:-
First attempt was to use the petrol ride-on mower (John Deere L100 with turf tyres), but it was a pain in the proverbial backside when changing direction on the slope, producing a lot of wheel spin (being rear wheel drive) and making it too hard to get around. Scratch that idea.
I had an old ZB6000 (Zen-Noh copy of the Kubota B6000) that was sitting out in the paddock for the last 5 years and was broken. This is a good size for the job, is 4x4, diesel, and more tractor than ride-on mower. So I asked the local tractor mechanical shop to advise on the suitability of reviving this and adding a small slasher to the back. No probs they tell me. I asked them to do the job as, even though I am fairly good with mechanical things, I knew nothing about tractors and diesel engines.
What happened:-
The ZB6000 tractor repairs went pretty well. New nozzles for the 2 injectors, new filters, replaced all the fluids, replaced all the seals in the front axle (ouch, that was pricey), and a few little things to prevent the water from getting into the gearbox. All good. The tractor felt better than it had ever been since I had it. Turned out it was partly broken since I bought it. You learn from these things <grin>.
So then I bought a Daiken 1.0 405 series galvanised slasher brand new. They do not put rear jockey wheels on these small implements so it just rides on the side skids. Nice looking slasher. Do you guys call them bush hogs over there?
Fitted the slasher to the 3PL, cut down the PTO shaft to suit. Then went out into the paddock to see how she went.
Well, did I get a shock! On flat ground it was OK. I noticed it a bit light in the steering though. And when I got to a bit of a slope in softer ground, the front wheels came right off the ground and I had to use the brakes to keep it going reasonably straight. So dangerous I only did about 5 minutes of experimenting and then took it back to the shed. This will just not do the job.
What is my thinking so far:-
As I have already spent more on this project than I wanted to, it would be good to keep the cost down. So far, spent about $3000 reviving the ZB6000 and $1700 on the little slasher. I think I could get the money back for the tractor, but would lose a bit on the slasher.
I figured I have 2 choices here.
1. Sell both the slasher and ZB6000 and get a similar compact tractor with mid mounted mower.
My concern about this solution is there are some rocky patches of ground and some dead branches around the trees which might give the MMM a hard time and reduce the life of the mower deck.
I found a Kubota B7100 with HST and MMM for around $5000 and nearly bought that, but got beaten to it by another cash buyer that got there before me. This might have been a lucky break for me :).
2. Sell the ZB6000 and get another compact tractor that can handle the slasher.
I feel that this is a better option, but am not sure how to size the tractor for the job. This is where you good folk could help me the most.
So looking forward to any feedback you can give.
Cheers, Graham
   / Think I need a better tractor - B6000 with slasher puts front wheels off the ground #2
How about putting some weights on the front. If you have a use for a front loader that would hold it down too. Tractor might be too small for a loader though.
You could put a tail wheel on the slasher for not too much money probably.
   / Think I need a better tractor - B6000 with slasher puts front wheels off the ground #3
Being the 1 meter width, your tractor should have enough power.
It is normal with any tractor to have to put some weight up front with a heavy rear implement. I use my front loader or I'm popping wheelies with my 48" cut bush hog.
You might look into getting some suitcase weights if you aren't the type to invent your own.
So X2 on what deano said.
   / Think I need a better tractor - B6000 with slasher puts front wheels off the ground #4
bigdeano said it
Front weights.
Suitcase weights they are called here. 100kg is not too much.
Equal to the weight of the slasher.
Thanks for replies.
The slasher is 155kg (~340lbs). That's a biggish weight and could cost a bit when there is no mounting bar to speak of.
I'll look into the costs of this option.
The mechanic have quoted $450 to fabricate rear jockey wheel, plus fitting.
After 2 weeks still no price on front weight mounting. Could end up expensive.
   / Think I need a better tractor - B6000 with slasher puts front wheels off the ground #6
Your front end weights don't have to be OEM. Any heavy items will work just fine, scrap steel plate bolted together in a stack, a heavy plate box filled with concrete and other thick metal scrap, etc..
   / Think I need a better tractor - B6000 with slasher puts front wheels off the ground #7
G'day Cobber and welcome to TBN from Tassie.
A quick site search, using Orchard Mowing as the key words in the google custom search box at the top of this page has resulted in many responses. Particularly regarding orchard flail mowers. Good reading.
Enjoy the site.
   / Think I need a better tractor - B6000 with slasher puts front wheels off the ground #8
G'day Graham. 'Suitcase weights' was the first thought in my mind as I read your OP then I scroll down to find the other guys saying the same. You need to counter-balance the weight of the rear implement. Save your money on the tail-wheel. You don't need it. A 'Slasher' (as we know them too) rides on the side skids quite well enough to chop down your vegetation.
Your JD ride-on will never cope with either the grass or the sheer area. Leave it for 'home' use.
You can fabricate a bar to bolt to the front of your chassis to hold the weights. - Or - You could make a box to hold scrap steel but the suitcase slices are easier to lift on/off by yourself.
The American have these 'Bush-Hogs' which are slightly different to our 'slashers' having a tail-wheel and different blade set-up it seems.
Oh, and you confuse me with the B6000 and the ZB6000 interchange terminology. You said you had the Zen Noe (sic) "repaired" and now refer to a B6000?? If you have a "Zen-Noh" it would be a "ZL1800" or something similar?? The B6000 is a Kubota.
P.s. Zen-Noh are big into that Wagyu Beef craze that's sweeping the restaurant world by storm currently.
Regards,
:drink:
2014 VOLVO VNM DAY CAB (A50505)
2014 VOLVO VNM DAY...
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
2012 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A48081)
2012 Chevrolet...
1267 (A50490)
1267 (A50490)
Mahindra 7095 Tractor with Loader (A50490)
Mahindra 7095...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
