wade simpson
I just bought a 5' box blade on Fri and used it for about 4 or 5 hrs. Everything worked great. Later on that night I went out to start working on a new part of the road. everything was working fine then I noticed the tractor seemed to be bogging down more, I just thought I was losing traction . It was dark so I couldn't really see much so I packed it in for the night.
Next morning, back at it. As soon as I started pulling I knew something was wrong. The tractor could barely pull the BB without spinning the rear tires, I checked to make sure I was in 4wd. The front tires were not spinning with the rears. I took the bb off and put on the rear blade, same problem, will barely pull the blade, even in loose soil, without spinning the rear tires.
I lifted the front and spun the tires, the differential seemed to work but not always. It seemed like I could make one wheel turn without the other turning. I put the bucket flat and moved slowly fwd while lifting the fronts off the ground, at first the front seemed to be turned under power, the second time they didn't turn.
I bought the BB from the same dealer I bought the tractor from and asked a few times if the tractor could handle that size, he said it could. I always work in low range, stop to shift, never force the shift but move the tractor a little to let it slip into gear.
Anyway, off to the mechanic, hope it is not too expensive if it turns out to be misuse.
Any similar experiences?
