Think I Bent My Grapple Cylinder
   / Think I Bent My Grapple Cylinder #1
wvpolekat
Platinum Member
Buckhannon, WV
1947 Ford 2N and 2003 Kubota B7500
I think I may have tweaked the cylinder on my grapple.
In the middle of the travel it seems ok, but at either end it seems to bind up. This happens even with the cylinder removed from the grapple. On extend, if I pull I can get it all the way extended.
Visibly, it isn't bent.
A shop that can check it out is an hour away. Replacement cylinder runs about $80.
Is there anything I can do to verify things or should I just buy a new one?
   / Think I Bent My Grapple Cylinder #2
Pull the shaft out , and put a straight edge on it in about 4 different places. Maybe check the pins, and lube them.
   / Think I Bent My Grapple Cylinder #3
Once you have determined that the rod is bent (with a straight edge as JJ
suggests), you can straighten it with a press. Or have a shop do it. It
is very easy as long at the rod is not bent too far. I have done it multiple
times.
Honestly, I am not equipped to pull it apart. No workbench, vise, any of that.
I am thinking that the best thing to do is to just replace it. By the time I drive to a shop to have it looked at, pay for gas, pay them, I am at the same price as a new one.
I am 99% sure I bent it when I had it on the trailer. I put the strap for the loader over it, but I didn't think I cinched it down hard enough to bend it.
Club Car Cart (A51694)
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
2013 Toro Workman HDX Scissor Lift Utility Cart (A51691)
2013 Toro Workman...
2019 Nissan Versa Sedan (A51694)
2019 Nissan Versa...
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
