Things happen quick on Mower
   / Things happen quick on Mower #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
So thought I would share last weeks mower safety incident with you guys. It kind of exemplifies in my mind how several things can all go wrong and the coincidences can pile up rapidly to turn something minor into something major in a hurry.
My wife has a Lawncare, Landscaping business. 18 + years of doing it.
This parcel the tenant is supposed to pick up debris. Powerline folks had worked on the pole about 2 months back and dropped a big rats nest of aluminum wire at the base of the pole. Hanna had worked around it for a while hoping the Tenant would do their obligation and clean up, but finally go frustrated so while running back to the truck on the Lazer Z mower, with blades off, she picks up bundle of wire and put's it on the foot rest deck. (flat spot behind your feet) She is going along back to the truck and something vibrates, the wire bounces and goes towards the front at the same time a loop of the wire somehow coils over the blade engagement pull switch, wire pulls towards the front of the mower pulling out (turning on) blades then ripping blade switch off of mower (with blades engaged) then the other end of the wire snags now running blade and whips rats nest of aluminum wire out from behind SWMBO feet. An end lashed the back of her leg just above the boot and took some skin with it as well as a pretty deep bruise.
All in all she got extremely lucky as had her string of luck continued it could have hooked around her leg and really done serious damage before she could have gotten it to shut down.
As it was it is a $25 switch and some pain and discomfort for a bit as a reminder of how quick things can go astray.
Be safe.
   / Things happen quick on Mower #2
Could have been worse, as you say.
Now, what did we learn from her experience?
Can't imagine a tenant actually picking up wire debris left by powerline folks. I can imagine they might have to pick up their yard toys and playthings before having lawn mowed.
   / Things happen quick on Mower #3
Glad she is going to be ok , scary stuff ! I would have thought the tenant would have sold the wire for scrap !
   / Things happen quick on Mower #4
Wow I am glad that is all that happened considering how much worse that coud have turned out.
   / Things happen quick on Mower #6
It would be easy to say she did something wrong, but I don't think she did. It sounds like something I would do. I also had and experience with a piece of power line. I hit it with my mower, but it was a small piece.
   / Things happen quick on Mower #7
Whew that's to close for comfort,glad the hand from above was touching your bride.
197359 (A50458)
197359 (A50458)
2011 Cadillac SRX LUXURY (A50324)
2011 Cadillac SRX...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
HONDA EU2200 INVERTER (A50854)
HONDA EU2200...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
