Things are might quiet here.
/ Things are might quiet here. #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
Yepper not much going on. Mine are working as designed. Got my first cutting hay crop in, zero defects. Fixin to get my drum back on the 6530 to cut the Bermuda patch for equine feed. Rain has been super. It stayed dry for my cutting and then got 1.5 and about a week later 2.25 this past Saturday. Regrowth is soaring. Weather looks good for the coming week for the Bermuda harvest.
Good farmin to you.
/ Things are might quiet here. #2
Been using my 2400 for bush hogging, mowing lawn and a little loader work. One tie rod end started to unscrew from the steering cylinder but a couple of wrenches fixed that up real quick.
We had a very cool wet May so getting corn planted & 1st crop hay in around here was challenging. From April 25 to May 25 we had 9 inches of rain and only one time 3 consecutive days with out rain. I will take rain over draught any time though.
Here is hoping your Bermuda harvest goes well.
/ Things are might quiet here. #3
Been wet mid to late spring here,garden finally starting to grow haying need to pick certain areas because wet ground,good thing is not hearing about dry wells....yet.
/ Things are might quiet here. #4
Busy here, too.
I have put 91 hours on my 3510i since I bought it last July.
No failures of any kind, other than one safety switch in the starter circuit that needed adjusting.
And the mount my seats mounts to just doesn't spring much, I'd like to change that.
/ Things are might quiet here. #5
Sounds to me like it's quiet because everybody's out working their tractors instead of talkin' about them. I just helped a neighbor put in a back yard moving 30yds of fill dirt and spreading it out using a box blade and back blade. Difficulty factor was raised by the very nice redwood 3 ft. retaining wall he built along the back side of the house along the walkway and "sunken patio". (hence the fill dirt) and the multitude of trees in the area. Really appreciated the turning radius on the Branson for that. Brought in and spread 130yds of gravel on our driveway. That covered about half the drive but that's all that needed it. Hauled and dumped with a dump trailer 5yds at a time (wishin' I hadn't sold my dump truck last winter) leveled and "smoothed" it with the Branson and a 7' land plane. Pretty impressed with the land plane, works much easier than a back blade or box scraper for that job. Dropped some trees two days ago, used the tractor to skid them up to an area we could buck and cut them up for firewood. Have time to be on here this morning as I need to go to town (40 miles) to pick up some fittings to put in a new water heater. Redecking my flatbed trailer and haulin' hay will be the next little job. Still need to finish (one post set) 600' of fence along my lower drive. The 3pt digger is sitting in the second dug hole just waiting. I find that is the easiest way to unhook one from the tractor if you don't have a stand built for it. It's now 730am so gotta get movin'.
Thanks. We are in our 2nd year of recovery from a 5 year drought here in N. TX. Totally agree you that wet is better.
Busy here, too.
I built a bracket to fit under the plate to which the seat is mounted and mounted 2 of these:
732-�5182A by Troy-Bilt
If that doesn't transfer for you, they are used on some Cub Cadet and Troy mowers. Cub Cadet P/N is 732-05182A...just google search that number. I first noticed them going into a TSC one day. Was tired of the "valve spring" hard springs under most seats. Bought a set and now most every riding machine on the place has them installed except for air seats which I have in the 6530 as standard equipment and the 2400 (aftermarket i installed on this machine).
Agree on the "out working".
On the auger, I too work alone and they have been a problem. I had a spare 6" so I augered it into the ground with about a foot sticking out. I remove the auger on the digger when finished (1 bolt for me) and set the digger stem in it, then disconnect from the tractor. Works for me.
Some folks around here have old swing sets sitting around and hang then from there.
/ Things are might quiet here. #9
I don't like leaving an auger in the ground - if it rains, the hole fills in.
Not sure what the top of your auger looks like (hex? round?), but mine is the exact same size as 2-3/8" oil field drill stem.
A short piece of drill stem stuck in the ground is 100x cheaper than an auger!
/ Things are might quiet here. #10
Mines been busy cleaning up the property. Bought new discs, 96" land plane leveler, have a shop to put up, lots to do. I was just cruising eBay and there and there almost zero postings for Branson. Hope all is well.
If you are talking to/about me, I bought the digger with 3 augers" 2 ea 6" and one 12". One of the 6" had the tip broken off.....PO drilling rocks. So I dug the hole with the good one, swapped and augered the bad one in. There it sits. Over the years I said I needed a 9" like I had with my previous one but never got "A-round-TOIT". Grin.
/ Things are might quiet here. #12
Does anyone have any info on a future 47 or 50+ hp versions of the 25 series units? B.
/ Things are might quiet here. #13
Not that is for public consumption. :)
In general I would say that I suspect in the next year or so we will see the 25 series covering a similar horsepower range as compared to the current 20 series. How much horsepower are you wanting?
Good farmin to you.
Got her up yesterday, no rain on it. Today it's prep the SS regrowth. I cut it earlier than I had wanted (2nd cutting) day B4 yesterday when I cut my Bermuda as I saw some small signs of Sugar Cane Aphid infestation again this year. May get a shower on it but Intellicast said 60% for .06" so that shouldn't be a problem. That should do it for me for the year.
/ Things are might quiet here. #15
I don't know Dave. It just seems with the 25 series beefier status they would have higher HP numbers. If 42hp in the 25 series is good, why not go for broke and bump it up to 52hp? It's nice to have it if and when you need it. B.
/ Things are might quiet here. #16
I suspect we will see the 25 series going up to 55 HP eventually, but it will not be that much different than the current 55 HP 20 series, the 5220. By the way, I don't have an inside scoop, I'm just speculating.
2002 FREIGHTLINER CST120 (A60736)
2002 FREIGHTLINER...
Hustler super Z zero turn (A56859)
Hustler super Z...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2014 Dodge Grand Caravan Van (A61569)
2014 Dodge Grand...
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A60736)
2012 GALLEGOS 130...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
