Things Are Looking Orange
   / Things Are Looking Orange #1
Dranrab
Bronze Member
Perkinston MS
Mahindra 1626 HST
I mentioned in a previous thread that I have 10 acres in South MS that I will need to tend. As of right now I have a 20x300 driveway that has been cut out. I'll need to have some gravel brought in so that I can make a proper driveway out of it. I have about an acre cleared that will be the place where a house will be built in 5-6 years when I retire. I'll keep it bush hogged down. I have about an acre that I will plant a spring and summer vegetable crop and a fall and winter food plot on. I also have about a wooded half mile perimeter walking path that I will maintain.
I could make do just fine with a sub-compact, but I have been told so many times to go a size larger than I think I'll need that I decided to go with a small frame compact. I have surfed Craigslist ads exhaustively, and a decent compact with an FEL is nowhere to be found in my area. So I have decided to go new. My research tells me I can expect good service from any of the manufacturers. I narrowed it down to a Tym T264, Kioti CK2510, Mahindra Max 26, LS XJ2025, Branson 2510H, Kubota B2601, Yanmar SA424 and SA324, Massey 1526, New Holland Boomer 24 and JD 2025 R. HST and FEL are a must for me.
I have had 5 right shoulder surgeries and it remains deficient. For that reason I struck all the machines that didn't have the FEL control at the fender. That left the TYM, Kioti, Kubota, Yanmars, New Holland and JD tractors. I can get the TYM for the best price, The dealer is about 50 miles from the land. You all know how tractor pricing works. There are good discounts and there is 0% financing but rarely both. The prices on the competing machines with my desired implements is coming in between 19K and 22K.
I did some math. $19,000 at 5.5% financing costs the same over the life of the loan as $21750 at 0%. The TYM is about 19K with insurance and 5.5%. The Kioti and Kubota are at about the $22,000 mark with insurance and 0 %. The others are either more expensive or don't have local dealers. The TYM dealer is 50 miles away and TYM is a lesser known entity. I am going to strike them for that reason.
That leaves me with orange. The Kioti dealer is about 12 miles away, and I kinda know the owner. He's the brother in law of my best bud. The Kubota dealership is about 25 miles away. Kioti and Kubota enjoy a good reputation with their owners, but Kubota has better brand recognition and is generally thought to be the higher quality product. Of all the tractors listed above, the Kiote has the largest engine by a considerable amount, the highest weight by a considerable amount and its capacities eclipse the Kubota by a decent amount. As it stands right now the Kioti would come with Woods implements which change the financing a bit, and with a non-Kioti insurance provider. Packaged out, it'll likely cost a little more. My dealer doesn't have one right now, so I won't be able to lay eyes on it before I buy it. The Kubota comes with Kubota implements and Kubota insurance. I have been able to do a brief demo on one and I like it.
Each orange machine comes with advantages. Do any of our learned members have any constructive feedback?
   / Things Are Looking Orange #2
Sounds like the Kioti is the heavier stronger machine at a comparable price. When comparing tractors weight is about the most important thing you can consider. It’s what puts the horsepower to the ground. Without weight hp is worthless unless all your work is stationary pto work.
   / Things Are Looking Orange #3
The Kioti CK2510 weighs 2,260 pounds bare tractor; engine = 24.5 hp/100 cubes @ 2,600 rpm.
Two (2) range HST.
The Kubota B2601 weighs 1,632 pounds bare tractor; engine = 24.3 hp/68.5 cubes @ 2,800 rpm.
Bear in mind Kubota weight is without fluids, so weight with POL will probably be ~~1,720 pounds.
Three (3) range HST.
Greater weight of Kioti offset by 3-range HST on Kubota (lower/LOW, higher/HIGH)
I would factor in proximity of Kioti dealer as the tie-breaker and go with CK2510. (Close call.)
Of all the tractors listed above, the Kioti has the largest engine by a considerable amount, the highest weight by a considerable amount and its capacities eclipse the Kubota by a decent amount.
Interesting that CK2510 develops 24.5 hp/100 cubes @ 2,600 rpm ~~~ relatively high revs. Kubota L2501 develops its 24.5 hp/100 cubes @ 2,200 rpm.
In my OPINION greater engine cubes of Kioti @ 2,600 rpm may be some but not much an advantage.
Good point on the HST range. I forgot to mention that. I still have some final things to negotiate on the Kioti.
   / Things Are Looking Orange #5
The CK2510 is probably more comparable to the Kubota L2501 rather than the B series which is significantly smaller. The L2501 is about 2600lbs bare tractor and makes ~25hp from 100 cubic inches. Big, low stress, non-emissions motor and three range HST. However, it does have the loader stick on the loader arms which wouldn’t work for you.
   / Things Are Looking Orange #6
I would at least check price deference on the Kioti CK3510. The HST has 3 ranges with more weight and power. Being a HST is what you want, the extra HP will be very useful and worth a little extra up front.
The CK2510 has 19 PTO HP(claimed) and the CK3510 had 30 PTO HP(claimed). That makes a big difference if you plan on running a mower.
Good luck in your search!
   / Things Are Looking Orange #7
Most Loader controls end in steel rod with a knob on the hand end and thread on the opposite end.
Consider how easy it would be to fab a custom shaped Loader control. Just a threaded rod, heated with a torch, then bent.
   / Things Are Looking Orange #8
Agree ^^^^
The Kubota L2501 is comparable to the Kioti CK2610 in dimension and spec. They are both mid size compacts. The Kioti CK2510 is the largest of the small compacts. I am afraid the loader stick position on the L2501 would be difficult to work all day.
   / Things Are Looking Orange #10
EXCELLENT advice !!!!
2018 CHEVROLET 2500 SILVERADO (A52472)
2018 CHEVROLET...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2018 Wacker Neuson WL 38 (A52748)
2018 Wacker Neuson...
