thermostat wire diagram / color codes
   / thermostat wire diagram / color codes #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I just got stuck with somebody else's problem.
We use mobile office trailers at our construction sites ( Ge brand if it makes a difference.. ).. anyway.. they have one of those verticale mounted ac's onthe outside back wall.. " The wall mount".. apparrently the one in one of our units we need to use died, and we have another ac apparrently salvaged from a MH. bracketing, ducting, and 3-wire electrical is no problem to hookup.. however the genuises didn't remove the old thermostat from the salvage unit so i could see how it was wired.
'new' ac has 6 wires.. grn, brn, yel, red, blu, wht and is a grandaire.
old unit only has an ATEX sticker on the side electrical access panel. Looking inside near the pump and lines I can see a copelan tag. Old thermostat is a white-rodgers.
Just checking to see if this old thermostat ( since it's hardwired in place ) will be compatible or?
any advice appreciated.
thanks
soundguy
forgot to add.
wiring in office trailer for thermostat is 5 wire cable, with 4 used..
grn, yel, red, wht are used, and blu is tied off and not used at the thermostat.
soundguy
   / thermostat wire diagram / color codes #3
forgot to add.
soundguy
Can you provide the name plate data from the unit you are going to install?
also there should be a wiring diagram glued somewhere inside the electrical box that will indicate the terminals which will need to be connected.
The model number for the thermostat would also be helpful as there are severial types which have digital functions. is it a mercury switch type or digital unit?
You may try to look up the correct wiring diagram on the manufactur's web site as well.
if you want to PM me I will try to help you with further information.
Good luck!
   / thermostat wire diagram / color codes #4
here is the "standard" color code:
Terminal Designation Wire Color Function Description
Rh Red 24 Volt Hot for Heating
Rc Red 24 Volt Hot for Cooling
Y1 Yellow First Stage Cooling
Y2 Blue Second Stage Cooling
G Green
Grey * Energizes Indoor Fan
W1 White Energizes First Stage Heat
W2 Black Energizes Second Stage Heat
O Orange Heat Pump
Reversing Valve
Energized In Cooling
B Brown Heat Pump
Reversing Valve
Energized In Heating
C Brown** 24 Volt Neutral
(Common) leg
no data plate info on the unit we are installing.. it has been rmoved by someone other than me unfortunately.
thermostat is a mercury bulb style ( non digital ), and other than the ul tag info, and some printed in foil lettering on the circuit board.. there are no model numbers present that I can find.
I know that blue is not hooked up to the thermostat.
soundguy
Tomorrow I'm poping opent he inspection panel on both units and will report back what I find.
thanks to tom and box for the replies.
soundguy
   / thermostat wire diagram / color codes #8
On 6 wire T-stat line the blue will sometimes be used for the reversing valve on a heat pump, or as other have stated a 2nd stage heat or cool function. If I were wiring 6 wire (we used 8 on heat pumps just to have the extra 2 in case one went bad) I would do yellow for compressor, blue for reversing valve, white for aux. heat, grn fan and red of course 24 volt power with the brown most likely unused, but that's me and the company I worked for.
got it working using an 8 wire 'universal' thermostat. took a bit of head scratching.. but brown and blue were unused..
soundguy
2005 Ford F-150 4x4 Crew Cab Pickup Truck (A42744)
2005 Ford F-150...
INOP/NON-RUNNING 2006 Isuzu NQR Truck, VIN # JALE5B16967300138 (A44391)
INOP/NON-RUNNING...
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A44789)
1999 John Deere...
1998 John Deere 120 Midi Excavator (A42742)
1998 John Deere...
2016 VOLVO VNL (A45046)
2016 VOLVO VNL...
PALLET OF SAFETY SIGNS AND CONES (A45333)
PALLET OF SAFETY...
