snowcrash
- Joined
- Nov 21, 2011
- Messages
- 21
- Tractor
- nh tl90a, ford 5000, mf 231, ford 2000 & 4000 and some others
I installed a glow plug intake heater on our 5000 and instead of using a reservoir box to hold the fuel, I put a T in the return line near the top of the tank and ran a line to the heater.
I bought a new 5-wire switch to put on it, but decided against it because when you go to crank the engine, the switch turns off power to all the switch lugs except the glow plug and starter ones. I have an electric fuel pump on our tractor so it needs to be running when the engine is trying to crank so I stayed with the old switch.
Everything is hooked up right and I have a push button that feeds power to the heater when pushed.
My question is, what is the correct way to use a heater on one of these tractors? At first, I thought maybe just holding the button for 10 seconds, releasing and cranking it so I tried that one day.
I remember when using my test light, the glow plug stayed on when in the starting position of the key so I was thinking maybe you hold the heater button for 10 seconds and then while continuing to hold it you crank the tractor so I tried it yesterday but it was warm day so the tractor would have cranked without it.
It makes sense though that continuing to hold the button while cranking would work since you are sucking warm fuel into the intake but I figured I'd ask to see the correct way since we've never used one.
Thanks for any help,
Charlie
Charlie
