Thermostat ? for 530 ck AND model 32 hoe question also fuel tank question
   / Thermostat ? for 530 ck AND model 32 hoe question also fuel tank question #1
southernbound
Bronze Member
New Jersey
D530TC
Hola-I'm looking for a temp sending unit for my tractor. I'm not in restore mode yet until I get the time/space. Can I simply buy any aftermarket sending unit? What are my options? I'd just like to know i'm not overheating this beast.
Also, I'm missing pins/bushings for the hoe...I'm searching but having a hard time locating them. Anyone know where to start?
And...lol...Do I have to remove the loader pin above the fuel tank to remove the fuel tank? or can it be slipped out the front by disconecting the dash? (the tank is leaking through drain cup and needs repair)
thanks in advance for any replies, Rob
case 1966 model D530 TC
sn- 8289084
   / Thermostat ? for 530 ck AND model 32 hoe question also fuel tank question #2
A sending unit from a Case Construction dealer runs $45, and change. I don't see why a generic one wouldn't work, as long as the thread size is the same, and connection is the same.
Bushings still seem to be available, but not so much the pins. You may need to have it/those made. Here is a link to Case Construction, and an exploded view of the 32 hoe, showing part numbers, and description. Official Case Construction Equipment Online Parts Store and Parts Look Up. Parts for Case Equipment and Construction Equipment. Parts Store for Case Wheel Loaders, Case Excavators, Case Skid Steers, Case Original Parts. You can copy and paste the part numbers to a search engine to find NOS, or aftermarket parts.
awesome..thx for that link..i'll be using that for sure. I'm looking at service manuals for this. They run almost 200.00 bucks. Will these tell me how to remove/install tank?
   / Thermostat ? for 530 ck AND model 32 hoe question also fuel tank question #4
wish it was for a 530..I'd be all over it./ thx for trying.
   / Thermostat ? for 530 ck AND model 32 hoe question also fuel tank question #6
You need to match the resistance values on the sending unit to yours for the gauge to read correctly.
   / Thermostat ? for 530 ck AND model 32 hoe question also fuel tank question #7
ty. Lots of good info in that. That was actually confusing me the other day. I saw service manual and thought, if thats all thats in em, I'm not buying one..lol. It seems theres much more info in the full sets. Definately a great place to get started.
24in Tractor Backhoe Bucket BT4555 (A52748)
24in Tractor...
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
