Thermostart?
   / Thermostart? #1
flyingcow
Veteran Member
aroostook county maine
If i spelled it right,
The manual for my TN75 doesn't give much info for this button. i know it's for cold starting, but can someone remind me of the correct process to use this? This isn't a glow plug or manifold heater. Lived in the north all my life, been around equipment, just not used to this set up.
   / Thermostart? #2
You spelled it correctly. It is in fact a manifold heater. Key on, hold the button in for up to a minute depending on ambient temp, then crank it over while still holding the Thermostart button in. Release when the tractor runs on all cylinders.
   / Thermostart? #3
How many people wanted that "horn button" repaired?
   / Thermostart?
Thanks. i think i asked this same question last winter. usually the tractor is kept in the truck garage, if it's outside i plug in the block heater.
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2014 TROXELL 130 BBL VACUUM TANK (A53843)
2014 TROXELL 130...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
