Thermostart problems
   / Thermostart problems #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Greetings All,
I have a Yanmar YM2310 tractor. The thermostart quit so I bought the one recommended here from Amazon. This same thermostart is used on many other tractors, Ford being among them. Here is the link to the one I bought: https://www.amazon.com/dp/B00WIX756E?psc=1&ref=ppx_yo2ov_dt_b_product_details
I installed the thing and pulled the air intake hose from the manifold so I could watch it work. Turning the key to the thermostart position I saw the thing heat up, smoke, and then saw flames. The flames showing that diesel was flowing into the device and catching fire, just as it is supposed to do.
So then a few days later it was pretty cold and when I started the tractor it started much faster than it did before I replaced the failed thermostart. But then a few days after that the tractor was taking too long to start. It was very cold out but it still should have started faster.
Now, today, it was cold out and so I cycled the thermostart 2 times and still the tractor seemed to be taking a long time to start. So I climbed off the tractor, raised the hood, and took the intake hose off of the intake manifold and watched the thermostart in action. It heats up just fine, gets good and red, but no smoke or flame. Looking at the hose that goes from the diesel reservoir to the thermostart I see no movement of fuel. I am using Tygon fuel line which is translucent so a person can see bubbles and since there is an air bubble I should be able to see fuel flow if there is any.
Since there is no flame or even smoke, no visible fuel flow, and a good red glow from the thermostart I surmise that no fuel is getting to the hot parts of the thermostart. The fuel reservoir is full. Could it be that a brand new thermostart failed that fast?
I am pretty sure the new thermostart works differently than the original one. The original was much longer and had two wires going to it. I think the original one had a solenoid that opened a valve letting diesel flow. The new one uses only one wire. I don't know how it works but there doesn't seem to be enough room for a solenoid. So I'm thinking it uses something that opens a valve when it gets hot, like a bi-metal washer.
Anyway, since the thermostart is new it seems odd that it would fail so fast. Does anybody know how these things work? Rather than wait I would like to get the darn thing to work. I don't mind taking it off, even though it is a pain, because I have to take it off anyway to put a new one in.
Thanks,
Eric
   / Thermostart problems #2
I had to look at the part on Amazon and figure out what it is. They call it a thermostat but it’s really an intake heater. It sounds like a little fuel flows into it and catches fire to heat the intake? If you see it glowing it’s getting hot but maybe the fuel flow to it is the problem.
   / Thermostart problems #3
My ford has that type, but the fuel feed is off the injector return to tank line. That means the only fuel supplied to the Thermostart is what's in the injector overflow line or when the engine is cranking. There's a valve inside which opens to allow fuel to drip through the heat coil. It takes about 3-5 seconds of heating to open the valve. I'd check your fuel supply line and reservoir to make sure fuel drips from them.
Here's a video of how they work. You could test yours the same way.
I know how they work and said so in my post. I have the reservoir that is fed from the injectors. It is full. Fuel is not flowing through the thermostart. Fuel does flow out of the hose to the thermostart If I remove it from the thermostart. I was wondering if anyone had had this problem before with a thermostart, new or otherwise and fixed it. The valve must not be opening. Maybe I just need to take the thing off and try to get the valve to open by pushing something thin through the fuel opening. I hate it when I buy something new and it only works a time or two. Because of where the fuel injector plumbing is routed and where the air intake hose is located itis a pain to remove the thermostart. GRRR.
Eric
   / Thermostart problems #6
Possibly the little port caught a bit of dirt or garbage while it was being worked on, that is a very small orifice that is supposed to open when hot.
   / Thermostart problems #7
I didn't mean anything to the contrary. I meant you should test it like in the video. :whistle:
I did. I removed the intake hose and watched the thermostart while I turned the key. It just gets hot. I mentioned that in my first post too.
Eric
I too think that might be the problem. So I am going to get it hot and try to blow air through it backwards.
Thanks,
Eric
2013 FORD F150 XL 4X4 (A45333)
2013 FORD F150 XL...
2015 FREIGHTLINER CORONADO 122 SD (A45333)
2015 FREIGHTLINER...
2013 CAMBELT INTERNATIONAL CF2445 SANDBOX TRAILER (A45333)
2013 CAMBELT...
Coats Tire Balancer (A44502)
Coats Tire...
New/Unused 40ft High Cube Shipping Container (A44391)
New/Unused 40ft...
2006 Ford F-650 Dump Truck (A44571)
2006 Ford F-650...
