The time has come...
   / The time has come... #1
JonNY West
Westernmost NY
JD Sabre 1546 circa '95
...for you to weigh in, should you be so inclined, my TBN friends. Yes, yet another "what should I buy" thread, from a first time owner, though a reasonably well-informed one from the the benefit of your writings over these last many months.
Expected Use:
Finish mowing 4+ acres of former horse pasture, relatively flat, gentle slopes.
Need to navigate many split rail posts but few trees.
Snowblowing about 300 feet of driveway and parking area.
Perhaps some trail clearing, landscaping, misc. FEL work.
May use spreader for snow melt but probably minimal rear tph or pto use to begin with.
Models Considered:
BX25, B2920, JD 2520, (2930,3030 but have not test driven - like the features and possible factory cab).
Assessment:
In brief, thanks to may of your informative posts I'm aware of the differences between JD and Kubota with respect to turning brake location, position control vs. quarter inching, clutch pedal, 3 range hydro vs. 2, minimal speed/power of hydraulics on BX25 compared to B-models.
Both dealers are about 40-50 minutes away, though JD (Zahm & Matson) has several locations throughout region. Each have been responsive to my inquiries and have let me test drive. Each had positive comments about their competitor's machines.
Given the $2500 rebate and another $400 dollar reduction, I'm inclined to go with the JD 2520, w/FEL, quicktatch bucket, front mount blower, and 62"MMM for $20,400. Probably can get ballast box included with delivery.
Questions/Concerns:
The JD2520 has lower ground clearance but sits 3" higher to bigger rear wheels.
It is also a few hundred pounds heavier. I have some softer, wetter areas to mow, and wonder if this will be problematic, as even my lansdcapers ZTR leaves tracks, though I probably have more discretion not to mow when it is wet as they are on a tighter schedule.
It seems a bit more user friendly to me, though the larger size seems somewhat more imposing and I don't care for the hump on the floor from the drive shaft.
Based on what little I know, the 1026R would probably be the best choice for my needs. However, the rebates and some healthy caution about a new, already problematic release sway me toward the 2520.
I welcome your responses about the 2520 as a primary mowing/blwing machine and,
Any comments about utility or problems related to a cab (either factory or after-market).
Should I consider adding the diverter valve to readily change between the MMM & FEL?
Have also noticed that the JD blower does not have a hydraulic or electric adjustment for the chute vs. the B2920. This seems like an oversight to me and a big inconvenience, any thoughts on this and any other key differences that I have not considered also very much appreciated.
Many thanks.
   / The time has come... #2
you have done your homework well.an you have driven both tractors,now all thats left is get what fits your needs.an from what you say your choice is clear kubota.
   / The time has come... #3
looks like you got your mind setup on the types of tractors you would like. All is whats left is visiting both dealers and talk with them and resist the impulse buy till you had a night to mull over your thoughts and feelings with both dealers.
To me, the dealer impression of NOT pushing me but give me all info I need/want and be willing to take the time to talk with me is golden in my book. second, you need to sit in the tractors and take it for a spin and see how you feel. there is a tractor calling out to you, can you hear your tractor calling you;) .
As for your diverter question for MMM and FEL- I think you might be over thinking it Unless there is a specific model that does a wierd thing you are thinking of- theres none I am aware of. The MMM operates via mid PTO and the FEL runs via hydraulics and can be used same time or seperately when running MMM.
Good call, Radioman. Thanks for generously stating I was "overthinking". As noted below from the manual, this option only applies if I go with the independent lift.
Am I correct in understanding that it allows me to operate the height of the MMM independent of the 3ph? And if so, will that be something that I will later likely to wish I had added at time of purchase?
Thanks again.
"2720 Mechanical diverter for independent lift mid-mount mower/loader control
Control knob
Field install this kit to allow the hydraulic lines for the independent lift of the mid-mount mower and the curl circuit of the loader to remain connected at all times. Simply change the push/pull plunger knob on this valve from the operator station to switch functions and keep working. No more changing hoses or getting hydraulic fluid on your hands when switching between mowing and loader work.
NOTE: This kit is only needed if a customer has independent lift for the mid-mount mower AND a loader installed to be used at the same time. Also, note that this kit is for the 2520 and 2720 only."
Bigbull, Thanks for your reply. I'm lol, because the choice still doesn't seem quite as obvious to me as it does to you. There are numerous pros/cons to both (I won't lose Orange in the woods, but Green has Thermos to keep me hydrated when I'm lost). What does my description reveal to an experienced user that should make the Kubota choice apparent to me too? : )
   / The time has come... #6
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
MISC WRENCHES (A53843)
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
