TractorNH
Platinum Member
- Joined
- Apr 11, 2018
- Messages
- 641
- Location
- Southern NH
- Tractor
- Mahindra 2655 HST Cab, Deere 350C Dozer, Case 580CK TLB
So I've searched this forum and even through 13 pages of a chainsaw carrier thread and can't believe I've found little to no mention of the SawHaul chainsaw carrier made and sold by Kenny Finley in Chanute, Kansas. The SawHaul was originally designed for tractors and is priced well within reach for such a high quality product.
I don't work for SawHaul but I own a few of them and just wanted to share this with my fellow TBNers because it is by far the BEST way I have found to solve a problem so many of us have. This is the BEST saw carrier I have seen in terms of versatility and ease of use. I don't like others that you have to actually clamp the saw into. When you're on an off the tractor and need to make a few quick cuts here and there, having to unclamp the saw is just one more step to slow me down. On top of that, this is made for tractors.
About the SawHaul:
Very easy to install and high quality steel construction
100% Made in the USA.
Backed up by amazing customer service.
Many methods of mounting provide incredible versatility to mount the SawHaul to virtually ANY piece of mobile equipment.
No extra clamping, gravity holds the saw in place.
The SawHaul is a very affordable way to protect your chainsaw while giving the convenience of having it readily available.
Check them out at SawHaul.com Chainsaw Carrier | Chanute | SawHaul
This is the complete kit with several mounting options. You can also customize your order and only buy the parts you want.
Here is a pic of a SawHaul on my tractor.
I pulled several these pics to share from the SawHaul website which better show how it mounts using the "no-drill" method. You can also directly bolt the main SawHaul bracket to just about anything.
Here are a couple of pics of previous versions of the SawHaul showing how it can be mounted to just about anything
It even works for saws with longer bars by simply mounting two sawhaul brackets spaced farther apart. This method can accomodate bars up to 36" or beyond.
The SawHaul bracket even gives a convenient place to route a cable lock to secure your saw.
About the SawHaul:
