The Question I forgot to Ask My Dealer - New Hydraulic Implement Start Up
   / The Question I forgot to Ask My Dealer - New Hydraulic Implement Start Up #1
welyell
Bronze Member
Vashon, WA
Kubota MX5800
I just purchased a Land Pride SA20 Hydraulic Post Hole Digger, hydraulic driven to hook up to my 3rd function on the front end. I picked up an extra gallon of hydraulic fluid to replace whatever flows into the unit the first time I hook it up - BUT - I don't know if there is a procedure for starting up a new unit like this. Is there a process to bleed off the air while initializing it, or will the hydraulic system just naturally aspirate any air introduced into the system? Thanks in Advance for the responses :)
   / The Question I forgot to Ask My Dealer - New Hydraulic Implement Start Up #2
Hook it up and open the valve to operate it. I would do this is tractor engine idling. It should not take but a minute or two to fill the hyds on the auger.
   / The Question I forgot to Ask My Dealer - New Hydraulic Implement Start Up #3
+1.... no bleeding required.
   / The Question I forgot to Ask My Dealer - New Hydraulic Implement Start Up #4
The augur is continual flow so it will self bleed.
That said, you may want to avoid getting the cheap tractor fluid already in the augur into your HST.
I would open the return line into a container and flush it before connecting to the tractor return.
SDT
Thanks All!!!
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2014 Ford Transit Connect Van (A50323)
2014 Ford Transit...
2018 GMC Savana (A50120)
2018 GMC Savana...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
1267 (A50490)
1267 (A50490)
