The old worklight question
   / The old worklight question #1
JoeR
Platinum Member
Central Florida
Kubota L5030HSTC
I was thinking of mounting some worklights on the tractor, but couldn't decide where. I have a canopy and thought about mounting them on it, but I was worried about the vibration. Where do the factory worklights get installed on the L4330?
So the final questions is:
Should I mount worklights on the canopy or locate them where the factory would install them?? Wherever that is?
Thanks,
Joe
   / The old worklight question #2
Mount them as high as you can. I installed 5 lights, 2 front and 3 on the back. Don't worry about vibration, I've had mine on for 400+ hours and 5+ years without an issue, (and the rear lights are cheap foglights for snowblowing, under $5/ea).
   / The old worklight question #3
Joe, I just did my worklights and put them on the front and rear lip of my canopy, I get good height that way. I used a double pole double throw switch so as the front and rear can't be on at the same time. I also added a center rear as a backup light for night snow work. There was an open wire under the rear fender by the tailight that works with the ignition I used this for the backup light. Good Luck
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
SET OF (4) 11R24.5 TIRES (A53843)
SET OF (4) 11R24.5...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2012 DIAMOND CARGO FOOD TRAILER (A53843)
2012 DIAMOND CARGO...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
