The occasional big one.
/ The occasional big one. #1
David_G
Australia
Kubota BX23
BX23 - Occasionally I hook onto one that is a bit bigger.
Building the road. Approx 1 mile of it to do.
This section is slightly rocky.
Missed the real big ones though.
/ The occasional big one. #2
Well David my first thought was where or when was this shot taken, the enviroment doesn't look right this time of year. Then I saw that it could be
Australia. You are certainly putting the BX through a work out. Good job!
RaT
It was today, in SE NSW - australia, temp in the high 20's C or approx 80F. 3000ft up, digging a road to where I will build a house.
/ The occasional big one. #4
We hook onto a few big ones like up here in New England too - I pulled a bunch out last year digging out for a new driveway.
/ The occasional big one. #5
Luckily it fit in the bucket so I could haul it out to the pile..
/ The occasional big one. #7
Last one
/ The occasional big one. #8
Do you Aussies drive your Kubotas on the wrong side of the road too? /forums/images/graemlins/smile.gif Keep the pics coming. Sounds like you'll have plenty to share with us in the future.
/ The occasional big one. #9
Guys,
If you can lift it in the bucket it ain't big....
It's how creative you can get when you can't lift them....
I had one I dug out with my B2910 that had to weigh 2000lbs..
I pushed it across the field.... in low range 4x4...
It's always fun when you try to lift them and the rear wheels come off the ground... And mine are loaded to the tune of 300lbs each...
Regards,
Chris
Can't fit that one in the bucket. Will have to push it off the road.
They do get bigger round here but I am trying to miss all the decent sized ones. See attached (would not like to move that little one.)
The trick is to go around or over that which is not moveable.
We drive on the correct but opposite side to you.
2013 CATERPILLAR 305E CR EXCAVATOR (A64279)
2013 CATERPILLAR...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2018 Unverferth 3955XL Seed Tender (A63116)
2018 Unverferth...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
