The new TC60D
   / The new TC60D #1
Roto
Mid Maine
TC55DA and TC33D
I figured this would get some lookers hehe. just wondering if anyone knows about NH making a 60HP later this year. It was mentioned in another thread that they may boost the tc55 up to 60 hp. Any more details? I am looking at buying a TC55D within the next couple months and may hold out for more power if they are making it.
Mike
   / The new TC60D #2
Mike
Mike, with a stencil kit and a can of spray paint, you can make it TC90D and become the envy of the neighborhood.;) :rolleyes:
   / The new TC60D
This is what Larry said in another post. Somehow i had missed that answer until just now. I overlooked it somehow.
From Larry:
I have been given limited information about the new 60hp unit other than the fact that it will 60hp, same frame size as the TC55, and the model designation will be T2460 or something like that. I'm sorry I dont have more info right now but I will let you know the moment I do. What that DOES tell me is that if you are in need of a tractor right now, and the TC55 will do the job, I would jump on the 96 month financing from the standpoint of monthly investment. It wont get any better than that. However, if you still have shopping time left, you may want to wait. I know, its hard to wait, but based on what NH has been bringing to the market over the last year, I see even better things coming.
There are actually 3 new models in the CUT line coming out this year but at the moment all I have are proposed model numbers, all start with "T". I guess its the same naming convention as the new T6000 and T8000 series. My guess is that all models will be "T" something by next year. Time for all new literature again!
   / The new TC60D #4
Mike
Mike,
I have some good news for you! The new 60 HP class 4 tractor will be available starting April! The new 60HP will be named the T2420.
Here are some of the highlights for the model:
The new T2420 is built to work. In addition to the higher engine horsepower, it also has a new heavy duty clutch with the 12 x 12 Synchro Shuttle Shift transmission.
For applications that require frequent direction changes, the optional Electrohydraulic Shuttle Shift (EHSS) transmission is available to make forward / reverse shuttling smooth and easy.
Brake lights have been added as standard equipment.
The 270TL loader is compatible with the T2400 series.
Shipments are scheduled to begin in April.
Here are the details for this model:
DIESEL ENGINE
T2420
N844L-T Engine
60.0 Gross Engine hp @ 2800 rpm
51.0 PTO hp @ 2800 rpm - 12 x 12 SSS
50.0 PTO hp @ 2800 rpm - 12 x 12 EHSS
4 Cylinders
Turbocharged
Under Hood Exhaust
Two-stage Dual Element Air Cleaner
Full-flow, Spin-on Oil Filter
13.5 gallon (51.1 L) Fuel Tank
Single Fuel Filter with water separator
Quick Glow Plug Starting Aid
Flip-up Hood
INSTRUMENT PANEL
Analog Tachometer
Fuel Gauge
Coolant Temperature Gauge
Hour Meter
Engine Oil Pressure Warning Light
Battery Charge Warning Light
Cold Starting Aid Indicator Light
PTO ON Indicator Light
Parking Brake Indicator Light
Turn Indicator Lights
Hazard Flasher Indicator Lights
High Beam Headlights Indicator
TRANSMISSION OPTIONS
12 x 12 SSS (Synchro Shuttle Shift)
Left-hand synchronized shuttle
12 x 12 EHSS (Electrohydraulic Shuttle Shift)
Left-hand clutchless shuttle
(4) Synchronized Gears, (3) Non-synchronized
Ranges
Dash Mounted Gear and Shuttle Controls
HYDRAULIC SYSTEM
Open Center Hydraulic System
Dual Gear-type Pumps
Implement Pump Capacity:
12.0 gpm (45.4 L/min) - T2420
Steering Pump Capacity:
5.5 gpm (20.8 L/min)
Mid-mount Hydraulic Ports
3-POINT LIFT SYSTEM
Lift Capacity @ 24 in. behind link ends:
3465 lb. (1571 kg)
Category II, 3-point Linkage
Includes Category I Bushings
Position Control Lever
Drop Rate Control Knob
Crank-type Leveling Mechanism
Telescoping Stabilizers
Flexible Link Ends
ROPS
2-Post Foldable Roll Bar
Retractable Seat Belt
ELECTRICAL
12-volt, 750 CCA Battery
Safety Start Switch
Key Start/Fuel Shutoff
55 amp Alternator
Operator Presence System
12-volt DC (10 amp) Auxiliary Power Outlet
7-pin Outlet for Trailer and Implement Lighting
LIGHTING
(2) Halogen Corner Work Lights
(2) Halogen Headlights (high/low beam)
(2) Taillights/Brake Lights
(2) Flashing Warning Lights/Turn Signals
PTO
Rear
Independent 540 rpm
Flip-up Shield
Shaft Cap
DRAWBAR
Swinging
2-Position Extendable
REAR DIFFERENTIAL LOCK
STEERING
Hydrostatic Power Steering
Tilt and Telescoping Steering Column
BRAKES
Wet Disc
Right Side Mounted, Dual Brake Pedals
Parking Brake Lock Lever
FRONT AXLE
Four Wheel Drive (FWD)
Fixed Position Rims
56.4 in. (1432 mm) Tread Setting with R4
tires
REAR AXLE
Flange Type Axle
Adjustable Position Rims (except R3 turf)
52.8 in. (1341 mm) to 76.4 in. (1939 mm) Tread
Setting with R4 tires
OPERATOR'S AREA
Contoured Cushion Seat
Fore/Aft/Height Compensating Adjustment
with inclined track
Weight Adjustable Suspension
Deluxe Floor Mat
Left Side Step
Foot Throttle
Cup Holder
TOOLBOX
WARRANTY
Full Coverage - 24 months or 2000 hours
Powertrain - 36 months or 2000 hours
It looks like this will have the deluxe package options and the standard Boomer styling. I will post pictures when available but it sounds like it will look like the TC55 with new decals and cat 2 ball ends. Cant wait to get one into the dealership! :)
Hope this helps.
Regards,
Larry
   / The new TC60D
price? availability? interest rate? i thought the TC55 had the class 2 hitch also. Why dont they call it a TC60 since basically same machine heavier clutch and more HP.
Mike
   / The new TC60D #6
It appears to have a larger alternator, and I wouldn't be surprised if the new engine will accept B20 or B100 Biodiesel too. They are trying to improve the entire line of engines.
   / The new TC60D #7
New Holland is also introducing a T1520 which will be (in a nutshell) a 35hp TC30 with 29.5 PTO hp (gear) and 28 PTO hp (hydro).
The general dimensions and appearance of the new unit will be identical to the TC30--indeed it will be matched with the 7308 loader (same as the TC30).
As for why the new T2420 isn't a TC60, New Holland is doing away with its current tractor designations and returning to its Ford roots. Witness the introduction of the new 6000 and 7000 series and the aformentioned T1520. Also, the TC55 will be renamed the T2410 and the rest of the Boomer series will also recieve new monikers through the course of the year--though what they will become has not yet been announced.
   / The new TC60D #8
What is up with these STUPID names? :mad:
TC55, a 55hp compact
TN60, a 60hp utility
etc
a T2420?
is that 24hp? 20hp? 42hp? Why do I have to think to decide what is what?
STUPID. :mad:
   / The new TC60D #9
Not to mention that New Holland had a prior model 1520 that was but 23hp.
Should be fun for the parts guys.
   / The new TC60D #10
Larry_NFES - Does this one come with a cab?
2014 Dodge Ram 3500 4x4 Crew Cab Pickup Truck (A48081)
2014 Dodge Ram...
197637 (A50459)
197637 (A50459)
2013 Cadillac XTS Sedan (A48082)
2013 Cadillac XTS...
2014 Ag Spray Schaben Sidedresser (A50397)
2014 Ag Spray...
LOT LOCATIONS (A50505)
2014 Ford Escape SE SUV (A48082)
2014 Ford Escape...
