The LA115 and 44 inch snow blower saga-continued
   / The LA115 and 44 inch snow blower saga-continued #1
leonz
Super Member
NE USA
JD LA115, WH 244, Troy Built Horse 8 HP
Well,
I ordered a control cable for the 44 snow caster this afternoon
since the other one is frozen up.
I went through my 4th shear pin this afternoon and I decided
enough was enough after spending $2.80+tax on shear pins and
self locking nuts that go with them and I used grade 5 1-1/2 inch long 1/4 inch
bolts and nuts with blue loctite.
Seems like a slip clutch for this beast would be a better option as you
do not realise you have a broken pin until you see a small hill of snow
on one or both sides of the chute. A slip clutch would be easy enough
to do for sure.
AS it was near dark I decided to fix it, so it is one less thing to have do tommorow.
I ended up using a hammer and punch to clear the slugs of the shear bolts that were
stuck in the cross shafts.
I decided then that I was goig to see how it behaved with the heavy packed snow I
deal with and it worked well. Its just time consuming to deal with this when you are
trying to get to your wood pile with a trailer to bring back firewood as the ground
is almost frozen and the snow is dense.
I guess I will raise it up a quarter of an inch or so tommorow to see how well it does.
I still have to put the front chains on to make it stop skidding when the blower is down-More on that later.
I will be ordering the pneumatic casters from caster city on Wed. and by then I shoud have
the light mounted on the blower itself; you cannot see SH*& when the blower is raised
and the headights are on.
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
2005 International 7400 Chassis Truck, VIN # 1HTWGAAT75J048748 (A51572)
2005 International...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
