The Bobcat Tech just left; An after-action report AND HEADS-UP.
   / The Bobcat Tech just left; An after-action report AND HEADS-UP. #1
Spudgunner
Central Idaho Mtns
Kubota BX-23 & Toolcat 5600 D
The tech had been sent here to repair the main boom cylinder. It had been leaking for some time but the leakage had increased as of late...so it was time to get it fixed.
The following covers several items, some of which may be relevant to you and your TC. The items: 1) the leaking cylinder, 2) installation of a block heater, 3) discovery of cracks in the exhaust system (post turbo), and 4) what the tech said about extending the exhaust system to circumvent gassing yourself when working against a tall (>30") bank of snow along the right side of the TC.
1) The leak was where the "upper" line attaches to the cylinder. There is a hex-headed bolt/attachment/whatever that simply required tightening. Simple fix. I thought the problem would require repacking of the cylinder. Fortunately I was wrong.
2) Since the tech was here I asked him if he had enough time to install my block heater (p/n 6720736). He said it would be no problem and had it done in a jiffy. This would have been an easy DIY mod as it simply requires removal of the muffler/pipe assembly and knocking out the old freeze plug. The tech said that it's important to run a finger around the inside of the freeze plug hole to ascertain which orientation of the heater element would work best (most clearance between heating element and block casting). We ended up running the power cord into the area behind the engine access door and fastening it in there. It seemed like a fairly protected area. The heater element is 400W. I'm going to use one of those X10 Appliance Modules to allow me or my computer to turn the block heater on. I've done this before on a couple of my rigs and it works great.
3) Installation of the blk heater required removal of the muffler and pipe. Not a huge deal but the tech discovered 1 cracked weld and 2 cracks where the muffler mounting bracket is attached to the muffler. Not big cracks yet, but he ordered me a new muffler right on the spot. I made mention that the cracks didn't seem huge and he agreed; however, he said that when the part fails it would leave pretty much the whole exhaust system hanging from the turbo and that this would likely lead to turbo failure($$$). Heads-up: When it's convenient, you might want to check the exhaust system mounting brackets where they attach to the muffler. BTW, my TC only has 580 hours on it and has been used thoroughly but not at all in an abusive fashion. I'm hoping this is an isolated problem.
4) My biggest complaint about Toolcat usability this snow season is that when I'm running "flush" up against a snow bank taller than about 30" and on the right side of the TC, the exhaust gasses have a tougher time escaping and some end-up in the cab. Enough to stink and be very annoying. I asked the tech about any potential issues if I were to get a muffler shop to extend the tailpipe to the back of the TC. (I was concerned about backpressure effects on the turbo.) He basically said that with such a small mod, the effects might actually be positive but to make sure the pipe was solidly fixed to the TC.
That's about it. Hopefully my experiences with the exhaust system will save somebody some bucks.
Kevin
   / The Bobcat Tech just left; An after-action report AND HEADS-UP. #2
Kevin, Glad your "known" problems were pretty easy to solve.
Regarding the exhaust/muffler issue, did the tech say anything about whether your set-up on the D was the same as previous models, or unique to the D, since so much was redesigned/relocated?
On the block heater, there are also inexpensive plug-in pre-set thermostats that look like a 3-to-1 multi-outlet adaptor (wish I had a brand name or such) that I have used in the past and worked well. They are usually set for about 40 deg or so. Can power two devices at same time.
Good Luck
Good Luck
The tech didn't say anything about the uniqueness of the exhaust setup on the D. Since so much changed, I would assume that it must be a "D-only" implementation. I'll take a digital pic tomorrow and post it to this thread.
The thermosensitive outlet sounds cool. So to speak. Looks like Google time to me.
   / The Bobcat Tech just left; An after-action report AND HEADS-UP. #4
thx for the update.
ts
   / The Bobcat Tech just left; An after-action report AND HEADS-UP. #5
thx for the update.
ts
   / The Bobcat Tech just left; An after-action report AND HEADS-UP. #6
Kevin, Found what I used: See Thermostatic Outlet at Greenhouse Controls - Thermostat Controllers from ACF Greenhouses
Not where I got mine, but same unit.....cost $21.95 /ea..... paid less, but 10 years ago.....other places sell them as well I am sure.....maybe ebay even.
Going up next week to "visit" my TC, so will check out muffler bracket as well. No problems with machine or anything else so far, but many less hours than you.
Here's the pics. First is an overall view of how the engine sits in "D". Note the soot on the back of the cab. Second pic is a closeup of the exhaust system. You can also see the new block heater (look for orange color near middle of pic). The hairline cracks can't be seen but are in the field of this pic. Note the bracket and where the pipe from the turbo comes into the muffler. Those are the problem locations.
SKYJACK SJ6832RT SCISSOR LIFT (A51242)
SKYJACK SJ6832RT...
40' Sea Container (A50774)
40' Sea Container...
2019 KOMATSU PC290LC-11 EXCAVATOR (A51242)
2019 KOMATSU...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
UNUSED MOWERKING QUICK ATTACH ANGLE BROOM (A51244)
UNUSED MOWERKING...
