Thatch removal
   / Thatch removal #1
welder1
I cut some new ground with a 5 shank scarifier and then disked it afterward. This field was in native grass. I had cut it as close as I could get it with my bushog and then nuked it with glyphosate prior to tillage. My problem now is it has alot of thatch. Would it be better to till it in or remove it. I plan on sowing this in clover in late Sept. If removed what would be the best tool to use, a rootrake or a 3-point drag harrow? I have neither but have been watching Craigslist.
   / Thatch removal #2
Go ahead and keep disking and incorporate it into the soil. Organic matter is a good thing, and by the time you're ready to plant you won't even know it was ever there.
   / Thatch removal #3
I, also would go with the disc harrow for the same reasons. Ken Sweet
   / Thatch removal
I thought that might be the answer since a soil test gives a percentage of organic matter. I was concerned about seed to soil contact with all that loose stuff on the surface. I need a cultipacker but my 4-wheeler will have to do the packing for now. Thanks.
   / Thatch removal #5
+1 on this. You will be surprised how quickly it will break down if you get it into the soil a bit, and more organic material is always better! You have done well to till it in advance of planting, and that will help too.
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
2013 CHEVROLET SILVERADO 1500 (A52472)
2013 CHEVROLET...
WACKER NUESON PUMP PT2A (A52472)
WACKER NUESON PUMP...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52748)
DeeZee Crossover...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
