Thanks for the help all
   / Thanks for the help all #1
jaybirdt
Bronze Member
Holland New York
Iseki 1910f
Just wanted to say thanks to all for the help on my 1910. The problem was not gelled fuel but air in the injection pump.I cracked the bleeder screw on the pump and air came out.Left it open until only fuel ran out. I then cracked the lines going to the head and cranked it until fuel came out. Closed the lines and on the first try it fired right up. First problem I had was water frozen in the fuel then got air in the system when I emptied the fuel bowl. It started today at about 20 degrees no problem I also installed a 40 dollar magnetic block heater.So far I like the tractor as I really couldnt afford a new compact in the size range for about 11,000 dollars.PS I live in Holland to those who asked and its been one hell of a winter I already burned 10 cord of wood since Oct and my house is only 1600 square feet.
   / Thanks for the help all #2
Hey Jbirdt
Feels good when ya fix one of these tractors, doesn't it???
If this is your first tractor you will find that things get easier as you work with the tractor.Get a few of the kinks worked out and you will be a pro in no time
Good Luck
Bartman
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
UNUSED AGT MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED AGT MINI...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
(3) 14' X 14' ROLL UP DOORS, W/ MISC BRACKETS (A51244)
(3) 14' X 14' ROLL...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52748)
2004 Capacity Yard...
