TG1860G carb problem
   / TG1860G carb problem #1
uglyboywith11fingers
Georgetown, Ontario
2007 BX24TLB, 1998 TG1860G
My 1998 TG1860G (Kawasaki 2 cyl. engine) with 850 hours had a carb problem where it alternately starved, and other times almost flooded itself. Last summer I pulled the float bowl, and found that the float is made of some sort of plastic material... it seemed to have expanded slightly, binding on casting burrs on the inside of the carb. Sometimes it would stick up, causing the starve, sometimes it would stick down a bit, causing the engine to flood out.
I cleaned up the burrs on the inside of the carb, just above where the float bowl seats, and the problem seemed to be solved. A year later, in the last month or so, the problem has returned.
Anybody else run into this ??? Any thoughts ???
Pete
   / TG1860G carb problem #2
Last summer I pulled the float bowl, and found that the float is made of some sort of plastic material... it seemed to have expanded slightly, binding on casting burrs on the inside of the carb. . . .Any thoughts ???
Pete
Pete, if the float was indeed expanded, wouldn't a new float solve your problem? I would replace both the float and its needle valve plus clean the valve seat to see if that didn't help. I don't know about your fuel in Canada, but our ethanol added fuels here in the USA are sure causing lots of small engine problems. Some needle valves have rubber tips on the needles and the ethanol makes the rubber soft/deteriorated.
thanks, Jim... I guess that's the way to go. I'll see if my dealer can get the parts for me.
Pete
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50323)
1985 Eager Beaver...
NEW Fork Extensions (A53002)
NEW Fork...
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
2004 PETERBILT 379 9 CAR HAULER (A52577)
2004 PETERBILT 379...
2008 Toyota RAV4 AWD SUV (A50324)
2008 Toyota RAV4...
