Buying Advice Texas cab or no cab? (towing limit)
   / Texas cab or no cab? (towing limit) #1
jrbarnard
Bronze Member
Cedar Creek, TX
None
Well, it has been a while since I joined and I have stayed away because... well, I am easy to influence when I need a new toy (yes, a tractor is more than a toy heh).
So, wanted to chat and read input from you all to get my head wrapped around choices I need to make.
I used to have a Ford F-150, but traded it in for a 2018 Doge. It is not the Hemi, sorry.. family and what I do, simply could not justify spending the extra cost per month. Wish I had, but... let's face it.. did not need it and wanted to make the wife happy.
So, while it is a good truck, it is still a 6cylinder gas engine. The towing capacity STATES it is better than the new Fords in comparison, but, those are really just numbers in some aspects.
Now, I have 2 acres here at the house, and 330 acres at a ranch. I figure that if I need to get it to the ranch, I can generally invite any host of friends that want to hunt to haul it with their bigger trucks, and they have a lot bigger tractors so, not a huge issue, but...still, have to TRY to see if there is an alternative open to being self-sufficient, right?
So, back when I was "looking", I really wanted a cab with A/C. It appears to be like a $4k upgrade, not including the larger HP just to get TO that upgrade. Part of me is like, "to heck with it.. my friends have 55-60hp tractors.. if i need bigger, ask them".. and just get myself a 2400-ish tractor and call it done, forget the cab.. just something that lets me cut my grass at the house, move dirt, and I can haul it to the ranch myself.
But.. this is Texas.. a cab.. lol
So, that is where I am at.
I would have to build a lean-to to store the cab tractor under, doubt it would fit in a 8ft tall door, but a smaller one would.
I really want/need just a post hole digger, and as large of a grass/brush hog as I can get to make mowing 1-2 acres easier, plus the front end loader.
All of this stems around looking at that cab and thinking, "oh yea... 100 degrees outside.. I could use that..." heh
What would you all do?
Russ
   / Texas cab or no cab? (towing limit) #2
I don't have a cab. I'm in East Texas near Tyler and right now, the heat and humidity is extreme and it's only going to get worse in the next two months. You just hit a point when you cannot take it anymore and you are done. If you can get everything you want done in the morning, or you are willing to work later in the evening, after dark, then you can survive without a cab. I bush hog at night and I've been out past midnight fairly often.
My next tractor WILL have a cab!!!!
That was exactly what I was thinking.
Mowing after dark is going to be tough since I have a HoA.. yea, I know.. different topic altogether, heh.. but, the heat was what was "selling me" on the concept.
Would have liked to have it inside my workshop, but the 8ft height of the door also presents an issue.
LS has a 3037 with a cab. I think that vs the Kubota may be the two choices I have available. All the rest would just jack it up past my price range and "real" need, I assume.
Thanks for the input.
Russ
   / Texas cab or no cab? (towing limit) #4
I've got a cab on and would highly recommend it. Specific to the LS models it's not an overly big jump in price (dealer dependent maybe), and I feel I was able to get a larger cab machine in my price range vs. some of the other competitive models.
If you're going to spend enough hours on the machine it's well worth it in my opinion unless you're dealing specifically with working indoors or low ceilings. I live in Wisconsin so the A/C gets used nearly all summer long and the heat gets used all winter long. Here's just a quick list of cab bonuses:
Winter
- Able to dress in a sweatshirt and pants vs. full jacket/bibs
- No frost bite :)
- No snow dust in the face
Summer
- Able to work all day long in the comfort of A/C
- Keeps the dust/debris away when working with dirt or mowing
- Keeps the stinging bugs away
- Keeps you relatively out of the sun
General
- Can work in wet/rainy conditions without getting soaked
- No need to wear muffs to listen to the radio
In terms of machine size/capability it's definitely application specific, for what I do I'm very happy with my LS XR4155. I originally started shopping older loader tractors but I didn't want to be fixing it all the time, preferred to go HST with what I do, and the loader hydraulics are not nearly as user friendly as the new tractors. I upped my price but was finding that my new budget left me with limited capability or an open platform. That's when I started researching the LS brand. No tractor is truly perfect but I still feel it was the right buy for me when balancing out all my wants vs. needs.
- Decent amount of ground clearance for rocks/woods use
- Decent loader and 3 pt. capacity 2,700 lbs at the pins so probably close to 2,000 lbs real world lifting (dirt and rocks are heavier than you'd think)
- Still light enough to be used as a yard mowing machine as long as you're reasonably dry
- Large enough to move round bales
- Standard rear remotes and rear located raise/lower
- Cab with A/C, radio, etc.
Winter
- No frost bite :)
Summer
General
Thanks a ton. That helps a lot.
I do not mind getting a small tractor. I really would use the heck out of it, especially if I could haul it with my current truck. See, that is my biggest concern, if I go to big, I cannot haul it or cannot haul it easily or safely.
So, I am limited by a "window" of availability, more than anything. Too small, you get a cab but no A/C. Too big, you get it all but need a bigger trailer and thus bigger truck to haul it.
So, trying to find that right "sweet spot" and not get rooked on my first tractor.
So many choices :p
Thanks guys
Russ
   / Texas cab or no cab? (towing limit) #6
Purchased a Kubota L6060HSTC this past December. Decided to go cab from all the positive forum posts on them and was able to pull off the finances to do it.
It’s 95+ with heat indexes some days over 100F here in humid WV. I can’t imagine what Texas is like now. The cab allows me to work longer because when you do get out and back in you are refreshed from the cool air. I am so thankful I was able to get one. I can work it all day until I run out of fuel or time and not even care.
It literally has allowed me to probably be over twice as productive in the summer and winter because I spent more time cutting things and moving brush I just didn’t fool with before.
I see your predicament with the size. Fortunately I don’t have to move mine, but have to rely on the dealer for moving it for service. Mine lives under my lean to on the side of my barn.
   / Texas cab or no cab? (towing limit) #7
I have a Kioti with a cab and a Kubota mini excavator with an open station and I do everything that I can with the cabbed tractor (very cold ac) vs. the hot,hot, hot excavator. I have also noticed that my wife often goes and just sits in the tractor with the ac on because it is just so much more pleasant. Get the cab and ac and you will thank yourself many times over.
   / Texas cab or no cab? (towing limit) #8
My L5740HSTC fits through my 8' garage door where I service it. I don't know about the towing. I move mie so seldom, it was cheaper to pay to haul it than buy a bigger truck.
   / Texas cab or no cab? (towing limit) #9
I bought cab tractor three years ago and used it and open tractor in same field within about three days running a field cultivator. With cab tractor had my two youngest grandsons, one 4 and one 8 in there taking turns steering the tractor for part of the time. When I got back home got out of the cab clean as I could be. When I used the open station tractor I looked like had been in dust storm for a week and was surprised at how dirty I got in two hours. Of course no suitable for grandchild to ride on. I am big fan much of the weather of the cab. Now when not dusty and temp is say 70 degrees I dislike the cab greatly.
But to your decision: have you really check the weight of the larger tractor and see if it is tow-able with your pickup? Would not surprise me if it were. You did not mention trees and I would not be comfortable with a cab with tree or limbs to work around them, especially with an open door or window. Also if you get a cab be sure you secure the windows and doors for hauling. They can and do come open have read here of them be torn off in hauling.
I agree with all that was posted about benefits of cab.
   / Texas cab or no cab? (towing limit) #10
I actually get closer to trees now because I hated being whacked with bug ridden trees before. Only problem I have seen is very large limbs but I would not have gone under those with my ROPS. It does take a bit more concentration in between the actual trunks though on the hillside a slight tilt can cause a rub. I guess maybe it depends on your environment.
Good point about the doors and windows. My dealer never mentioned that. I can definitely see someone not getting them latched all the way. I’ve heard the same about some canopies although I never had an issue with my last one.
2020 Toro 6000 Series 60in Zero Turn Mower (A50322)
2020 Toro 6000...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2023 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2023 KOMATSU...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
