Testing Well Water Using Internet Companies
   / Testing Well Water Using Internet Companies #1
NY_Yankees_Fan
Veteran Member
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
Has anyone tested their well water using a company advertising on the Internet? If so, who did you use and would you recommend using them again?, a web site of the company would be helpful. I have done a search and have come up with several all charging from a lot, to a little, but which one did you use, would like to use one that will do a good job and not pay more then I should.
Tom
   / Testing Well Water Using Internet Companies #2
I had good luck with AE labs out of NY.
<A target="_blank" HREF=http://www.aelabs.com/>http://www.aelabs.com/</A>
They send you the sample jars and you fill and send back.
You have to get it back within 24hrs for some tests so shipping back the samples costs a bit.
It worked well for me since I have no local lab.
Fred
   / Testing Well Water Using Internet Companies #3
Or you can test it yoursef. I use to work for a company that manufactures very good and simple water test kits.
Here is a link to their website http://www.lamotte.com
What is it that you want to test for?
   / Testing Well Water Using Internet Companies #4
Kits are available for about $30 that will test almost everything. I bought one at Lowe's.
Terry
41 stump Grab Bucket (A53421)
41 stump Grab...
AIRMAN PDS 100S COMPRESSOR (A53843)
AIRMAN PDS 100S...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A53473)
2022 JCB 3TS-8T...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
