testing temp, fuel, and oil pressure sensors
   / testing temp, fuel, and oil pressure sensors #1
capthone
Riverton, Utah
john deere 4210
the fuel and temp gauges on my jd 4210 do not work. suspect senors may be bad. anyone know how to test?
   / testing temp, fuel, and oil pressure sensors #2
Two gauges going bad at the same time would not point me in the direction of the gauges themselves. I'd more likely start looking for either a common fuse or a common ground.
//greg//
   / testing temp, fuel, and oil pressure sensors #3
Remove the sensors from the harness connections. If the senders are two wire type, check for voltage at one terminal with key on engine off. If voltage is present, check for gauge movement, then briefly loop the two terminals together while checking for gauge reaction.
If the senders are single wire type, remove connector. Check for gauge movement with a completely open circuit (key on, engine off), then check while briefly connecting the harmess connector to a good clean ground.
If the gauge reacts to the tests, your gauge and circuit are good, and the sender is suspect.
I agree the simultaneous loss of two gauges points to a power supply problem, or incompete ground.
thanks your info was very useful
2011 RAM 2500 (A53843)
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53473)
2019 Energreen EVO...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2006 International 4400 Lift All LOM15-55-1S 60FT Material Handling Bucket Truck (A51692)
2006 International...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
