Problem is, that it is not easy or cheap to just swap out (drain 6 gallons hydro fluid, and cost is $75 and 4-5 hours). I also hate when I, or even a 'professional' mechanic resorts to swapping things out just to see if that 'fixes' it or not. To me, a proper repair to anything, is to find the cause of the failure, not just the failure itself. That can give one a way to prevent the problem from occurring again prematurely, either by preventative or re-engineering (and a few other ways). ^^^^^ It is a three wire, uses a 5 volt reference and ground. Third wire i believe goes to the controller with the returning value. What is that value? The tech manual states a running value, but i cannot replicate that if something else is the cause, HENCE my desire to want to test values non-running. _ OLD GRIND that is pretty cool you can do that with the tach, and def. a good item for the tool collection, but that wouldn't help at this point. Thanks for every ones input, just hoping some one will have done the bench test and post the values, or test procedure.
