Testing a hydro trans.
   / Testing a hydro trans. #1
joes_427_vette
Veteran Member
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
When I was trading my tc45 a dealer tested the transmission by holding the rpm @ 18-2000 rpm and ran the tractor forward and reverse at a very slow rate. Wouldn't say what he was looking for... just indicated the working capability was within specifications. When they are worn are they jerky or have a unique sound ? Just curious. I have seen some hydros in skid steers that needing replacing due to creeping in neutral and a loss of power.
   / Testing a hydro trans. #2
I suspect he was listening to the sound and getting feedback through the "seat of his pants" and right foot. He probably didn't tell you what he was looking for because his test was so subjective, especially if he didn't put the tractor under a heavy load enough to stall the transmission and lift the relief valve.
That is what has me curious. Not under load, high rpm, very slow as it could travel, and the feel through the hydro pedal. I was hoping a nh dealer could explain this as it may help spmeone in the future looking at a high hour hydro unit.
   / Testing a hydro trans. #4
I think he was looking to see if he could snooker you out of a couple more $$$ of trade in value. Probably trying to see if your muffler bearings were worn, or if the frobnatz bypass valve was degiberating properly. If not, those are real expensive !
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
1995 Olympian Generac 94A06155-S Generator (A49461)
1995 Olympian...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
