test your T273 rear remote PSI
   / test your T273 rear remote PSI #1
myyaz33
Platinum Member
Nebraska
TYM T273
Ok, wanted to check if any of you K2 owners have checked the PSI of your rear remotes and loader. Here is why I ask.
According to the T273 tractor manual the working pressure is 1813 psi. Now the LT200 loader manual says the loader relief valve is set at 2300 psi. The BT200 backhoe manual says the operating pressure is 2466 psi.
My understanding is the hydro pump feeds the loader valve(relief @ 2300psi) then feeds directly to the valve(levered) under the seat which allows the usage of the remotes. So if the backhoe plugs into the remotes, shouldn't the remotes be at 2300psi to ensure the backhoe is operating at its capacity?
Using a pressure gauge, I tested the PSI at the loader quick connects and indeed it was set right at 2300psi. Then I checked the psi at the rear remotes and found 1800psi. I know the valve that feeds the remotes has a pressure relief valve but I am curious if 500-600 psi would make a difference in backhoe performance and why would it even be set at 1800?
Is yours set at 1800psi?
What is the correlation between the tractors working pressure at 1813psi vs the backhoe operating pressure of 2466psi?
FYI- loader quick connects were 3/8" while the rear remote quick connects were 1/2"
   / test your T273 rear remote PSI #2
Did you have any flow at that pressure or did you just test the remote dead headed into the gauge? Maybe the relief at the valve is set incorrectly? Or maybe TYM has the specs wrong. That's a good possibility since I have found some inconsistency in their specifications in the past.
I dead headed at the remote right into the gauge. I went ahead and adjusted the relief to allow 2300psi.
Would like to hear from any of you K2 series owners or TYM dealers. What should the remote PSI be?
   / test your T273 rear remote PSI #4
What is is the max psi on your tractor pump. You said tractor system pressure was 1850 psi. If the pumps max psi is 2500 psi, then some circuits may be limited at 1850 psi. That leaves the possibility to operate the BH at the pumps psi limit.
The pressure will affect the force on a cylinder. If you increased the pressure on a 3 in cyl, by 600 psi, you will gain about 4000 lbs of force on the push stroke, and only 3181 on the retraction.
It all depends on what you think is good. Increasing pressure, will give more force, and loosing 600 psi will decrease the force. Speed of the cylinder will be determined by GPM output.
If the working pressure of the tractor pump is 1813 psi, that is all you will get at the BH. You could play round with the relief valves and boost that up some, but you have to take into consideration, the tolerance of the other components. You might boost one circuit and blow up another.
There are hydraulic intensifiers, that take low pressure /high volume fluid, and convert that into high pressure/ low volume fluid. That is something you probably will not want to get into.
   / test your T273 rear remote PSI #5
How do you adjusted the relief valve to give the loader a little more lifting power?
If you are asking me, I didn't. The loader was already testing @ 2300psi. The rear remotes are down the line in the hyraulics which is were the relief was set at 1800psi.
Still wanting to hear from any K2 owners or a dealer on what the PSI should be at the remotes?
   / test your T273 rear remote PSI #7
You do this at your own risk. Say you have a max pressure of 3000 psi. The cylinders installed may only have a pressure of 2500 psi. so the relief valve would be set a couple hundred lbs lower. Hence you could shim or turn an adjusting screw to increase pressure. I just did a calculation for a 3 in cyl. An increase of 500 psi, gave a 4000 lb increase, but that is on a straight line push. On loaders, you are always pushing on an angle, however, in you know the angle you can figure out the increase. It will always be less than a straight push. Based on the angle that most loaders are designed, they are probably only using about 2/3's of the cylinder power available.
   / test your T273 rear remote PSI #8
There is a misstatement here, and it will confuse some people. Max tractor pump pressure has to be equal to or higher than any pressure stated. You can have two relief valves set at two different psi level.
   / test your T273 rear remote PSI #9
You mean that when I stick my bucket under a rock and can't lift it or get the curl to lift it I'm not using the rams to their designed load?:confused:
Wouldn't the lift have a MA of less than one while the curl will have a MA of greater than one.
I agree with your statement that upstream pressure has to be higher but not sure what you mean by misstatement. I am only posting what is listed in the manual and trying to get clarification for the questions I posed in the original post. Basically, is the manual wrong or am I misreading?
1. What should be the pressure at the rear remotes?
2. What does "working pressure" at 1813psi mean in the tractor manual?
I have likely used some poor wording so, am going to try and clarify now that I have found the relief setting for the tractors hydrostatic pump. Here are some facts.
- Hydrostatic pump relief setting - 4978psi (according to Tractor Service Manual not Operators Manual pg.56)
- Hydrostatic Pump Pressue Test - Should be 1848~2417psi (according to Tractor Service Manual pg.70)
- Hydraulic "Working Pressure" - 1813psi (according to Tractor Operator Manual pg.90) What exactly is "working pressure"?
- LT200 Loader "Relief Setting" - 2300psi (according to LT200 Loader Manual pg.8) I have also verified the loader pressure at 2300 with my guage.
- BT200 Backhoe "Working Pressure" - 2466psi (according to BT200 Backhoe Manual pg.10)
System Feeds Like This
HydroPump>LoaderValve>RearRemoteValve
So first off, I am not sure I understand the terms "Working Pressure" and "Relief Setting" the way they are used in the manuals. But with my understanding and using the information in the manuals there is no way the backhoe should be able get to its working pressure (2466psi) as it is limited upstream by the loader valve relief set at 2300psi.
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
2022 John Deere RD35F Draper Head (A53342)
2022 John Deere...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A53426)
2015 INTERNATIONAL...
