Test run of Echo pole saw
   / Test run of Echo pole saw #1
pennwalk
Veteran Member
Lancaster PA
Yanmar 186D
I have been wanting to prune back the trees around the fields and down the farm lane and a pole saw looked like the tool of choice. I rented an Echo 230. It is a chain saw on an extendable shaft with a weedwacker engine at the bottom. It extends out to about 11 feet so you can reach branches up to 16 or 17 feet high. The unit had a 10 inch bar. I did cut a few broken stubs almost that big it was slow going but I got it done. The Echo weighs about 16 pounds so after a couple of hours my arms and shoulders were starting to feel it. After about 5 hours my body wanted to call it a day and I had so many branches down that it will take me weeks to get them all chipped. I guess I got maybe a tenth of what all needed to be done. Thank goodness the farmer planted the fields so the rest will have to wait till next year. The Echo is a handy tool. I wonder if there is any difference between the Echo and The Stihl?
Chris
   / Test run of Echo pole saw #2
I have a Stihl and it will wear this old man out pretty quick.
   / Test run of Echo pole saw #3
I recently purchased the Echo PPT-260 after compariing it to the Stihl HT101.
The store owner allowed me to fully extend both and compare the two for balance and feel. I initially was leaning towards the Stihl because it had a larger diplacement engine and was lighter but after handling both I decided on the Echo.The Echo , to me, was better balanced and "felt" lighter than the Stihl because of it. The Stihl seemed to have a little more of its weight towards the cutting head which made it feel heavier. I have used the Echo on several occasions and have been very pleased with its performance but as you found out it does put a strain on the upper body especially if you are using it for an extended period of time. I believe this is true of any pole pruner.
John Deere 7720 Turbo with Head (A52128)
John Deere 7720...
2020 KUBOTA RTV...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
Zero Turn Mower (A48082)
Zero Turn Mower...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
