Terex PT100G Demo
   / Terex PT100G Demo #1
fishfactor
Monroe, NC
(2) 2014 CAT 299DXHP / FECON
The guys from Terex stopped by our jobsite today and dropped off a demo unit. Here are my thoughts. I will be using a Bobcat T320 as a comparison in many areas.
Cab is sealed and pressurized and keeps you clean. It was dry and dusty outside and I couldn't find any cab leaks. No dust accumulated inside all day. The AC works great. I actually found that the low setting on the fan blows a little too hard. It was in the low 80's here today and I couldn't run it on the coldest setting. Cab is more comfortable that the T320 with storage for your gloves, etc. The seat didn't seem to have any suspension at all, which would be nice. There was a radio and although the cab is quiter that the T320, you would have to crank it way up to hear it at all. A waste of a few hundred dollars in my opinion. The emergency exit (to the rear) is suited for small folks. I'm 5'10" 185lbs and would have a little trouble getting out in a hurry.
Visibility was not quite as good as the T320 mainly due to the smaller windshield. At first it bothered me, but I adjusted. I also didn't like that you can't see all four corners of the tracks like on a Bobcat.
The machine has a radius lift arm lift. This limits the height you can stab through a tree a little.
The undercarriage design concerned me. I tried my best to throw a track and couldn't. I am just not familiar with the design and can't give any real feedback. CAT has been using it for a while so I'm sure it is fine.
Now to the important stuff....
Performance was VERY suprising. I almost can't even compare it to the T320 here. Granted the teeth only had about 90 hours on them and the head was a 2 speed where our head is 1 speed, but the Terex powered through trees that we had already went around in the T320. It was running just over 2000 RPM at WOT and they had the flow turned down to 37 GPM as that is what the head was rated for. It can be turned up to 45 GPM. I feed it a steady diet of 6" - 8" hardwoods for about 2 hours straight. It was in the low 80's and the water temp stayed at 210 or below. I wasn't familiar with the high tech computer inside or I would have noted Hydraulic temp, etc but I never got any warning buzzers or anything.
You can adjust the hydraulic flow from in the cab on the computer. I'm sure you can do more on there too but I didn't ask for that lesson.
The head uses no electrical connection which is nice. We have torn more than 1 wiring harness off of the T320.
The hydraulic system also has a bypass valve. If you start to stall the head, it goes into bypass. Clear the load and it starts back up. A stalling head also has no effect on lift or tilt. That is a huge plus over the T320. When it starts to stall, you can't lift or tilt without turning the head off first.
The radiator has an automatic reversing fan. You can also manually reverse it. Hopefully this will keep the radiator clean as it would'nt be really easy to access to clean if you had to. Maybe there is a trick to it, but after flipping the rear roll cage and opening the rear cover, you still couldn't get to it.
In summary, this machine outperforms the T320 hands down, no questions. My local dealer was great throughout the demo and has a large fleet of service trucks. The dealer had 2 guys there and a Terex factory rep stopped by as well. After a hour or so they left the machine with us and said they would be back later. While this isn't a real "I have a problem" service call, I feel confident I would get good service after the sale.
Pending the upcoming Bobcat T870 demo, the Terex is at the top right now as far as a future machine in that class. He is also getting some info on setting up one of their 125 excavators with a head.
   / Terex PT100G Demo #2
fishfactor, thanks for posting info about your demo test on the PT100G. I can't wait to hear how it compares with the Bobcat T870. Keep us posted!
   / Terex PT100G Demo #3
Very interesting unbiased post. Do you anticipate the T870 being much better hydraulically since it has the same flow as the T320? I understand that the machine has about 8hp more, but the machine is heavier and will take more oil flow into the loader cylinders when you move them. Also, I wouldn't think the engine torque would really be any greater since the displacement is the same as the T320.
   / Terex PT100G Demo
Honestly, I can't imagine the T870 competing with the PT100G after yesterdays demo, but you never know. Maybe they have dedicated more of the flow to the head that they do on the T320.
   / Terex PT100G Demo #5
I'm curious to hear your report. As you may know, I sold Bobcat for many years, I still have very good friends in the Bobcat company, and I still have fondness for their machines. Some of whom provide occasional insight into product development and market information. Based on what I have been told, the pump in the T870 is identical to the T320. One of my friends expressed concerns that the T870 didn't provide any real appreciable advantages over the T320 other than the lift height. The hp to weight ratio actually is decreased by just about 20% even though the T870 has 8hp more. This is because the T870 is 2970lbs heavier than the T320. He was also concerned about the width of the machine and the fuel consumption. I look forward to your report.
   / Terex PT100G Demo
If it's the same pump in the T870 as the T320 in will be a big dissappointment. The terex far surpassed the performance of the T320 and I am a Bobcat fan. I have praised the T320 since we had it.
   / Terex PT100G Demo #7
Hey guys, looks like he's kicken the cat out of the house. I like what i read on your post, verry informative. we been lookin for a new machine to buy for the past couple of weeks. Thanks for the help!
   / Terex PT100G Demo #8
Good review, thanks.
   / Terex PT100G Demo #9
Sorry to dig up an old thread. We just had a demo of the new terex this past monday. I was impressed a little. I really like the exhaust upgrade from the belly pan to the top. Sounded like the engine kept dieing back a little, but maybe a filter problem. Overall its a nice machine. Didnt care to much about the thin metal covering the PLASTIC fuel tank. I will be taking a friends advice and look at the supertrac. I was able to cut just as fast if not faster with my cat; like i said there engine was a little weak probably from a filter. We still have the terex on our list along with cat, lamtrac, and supertrac. Any sugestions where i can see a supertrac locally before taking a road trip to Florida?
   / Terex PT100G Demo #10
If you'll contact Tom King with Super Trac he will bend over backwards to get you a demo set up. He set one up for us on our place in Ga and left the machine with us for over a month.
FAKE (A52472)
FAKE (A52472)
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500 4x4...
2013 Nissan Titan Ext. Cab Pickup Truck (A51692)
2013 Nissan Titan...
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
2020 Nissan NV200 Cargo Van (A51692)
2020 Nissan NV200...
