Terex PT 110 regen HELP
/ Terex PT 110 regen HELP #1
Dozer654
Terex PT110
I have a 2013 Terex pt 110 I owned the machine for about 200 hrs now it has a total of 1300 I noticed when I first got it it would regen about every 8 to 10 hrs then it stopped doing it at all. I read online sometimes when you run them under heavy load it won稚 go into regen because you make enough heat to burn the ash off without regeneration. Then I got a check engine code 3251-16 which in the manual says it Particulate trap differential pressure : HIgh moderate severity (2) I also am losing power under load. I tried running a manual regen and the machine does not do anything it doesn稚 rev up or anything. I知 not sure if it痴 supposed to or not I never ran it manually. I called a Perkins dealer he told me to change fuel filters and run it full throttle. I did that and have had no change after a few days if anybody can point me in the direction or has experience with the regen I would really appreciate to ask a couple questions to point me in the right direction
Giyi Mini QA Auger (A60463)
Giyi Mini QA Auger...
EZ loader trailer (A56857)
EZ loader trailer...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
