tension for belt
   / tension for belt #1
celtic
help, while talking of the zforce 44, i have removed my belt and deck for cleanup and install of new blades, now when i put it all back together and pull the tensioner rod to tighten the belt, the pulley is allowed too far over and therefore the belt is rubbing itself. i do not remember seeing the tensioner spring so stretched, what am i doing wrong?
   / tension for belt #2
Sounds like the belt is too short. Did you match them up?
   / tension for belt #3
Assuming you are still using the same belt, it sounds like you have the belt installed wrong. There's probably a different route it can take. Been there - done that!
Bob B.
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
Hyster H225E (A47384)
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
City of Lakeland (A51691)
City of Lakeland...
