Temperature gauge
   / Temperature gauge #1
japody
Platinum Member
Richmond & Boydton VA
Ford 4000 & 5000, New Holland TN65, Mahindrda 2516
The temperature gauge on my NH TN65 goes to full tilt with 1 -2 minutes of a cold start. There are no signs of overheating from the radiator. I'm thinking a faulty sending unit. Any thoughts?
   / Temperature gauge #2
did you measure temp of the thermostat housing when hot? You might be able to find resistance curve for your sensor. basically if you find resistance at 212 (water boiling, corrected for elevation) and freezing at 32. Any where in between you can interpolate the expected result. basically you need to check calibration. just for comparison the following were finding for my temp sending unit. As the temp goes down goes up the resistance in Ohms.
Edit. Had a correction here that just noticed. Resistance and temp are inversely proportional. Type in in correctly on my original post. don't know if anybody noticed.
For 1700 tractor Operating temps:
Cold: sender=690 ohms, T housing = 98 , Radiator= 98 , Head=98 , Exh Man=98
Operating temp: sender=140 ohms, T housing = 172 , Radiator=170 , Head=174 , Exh Man=192
Hot,1/8" , right of middle: sender=92 ohms, T housing = 196 , Radiator= 196 , Head= 197 , Exh Man=210
1/8" left of H: sender=66 ohms, T housing = 210 , Radiator= 210 , Head=212 , Exh Man=250
2705 (A51691)
2705 (A51691)
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
2001  WABASH 53FT DRY VAN TRAILER (A52141)
2001 WABASH 53FT...
2012 Crane Carrier Low Entry Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
(6) HD 12' Pipe Gates (A50515)
(6) HD 12' Pipe...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
