A few weeks ago the temperature gauge indicated overheat condition. We shut it down and let it cool to check radiator levels, radiator was full. After a couple of times using it the Head heater came on with every start and stayed on for 15 min. Ordered a new sensor and went to replace it last Saturday. I did not drain the antifreeze and when I removed the sensor no water came out. I could see inside the head and it was dry. Of course I installed a new sensor and the problem was still there. The radiator was still full. I now believe the thermostat may not be opening and if not, why didn't the engine run hot? Being that the radiator is full I would have to assume the situation has been like this since I bought the tractor because I check the radiator levels when I check the oil. I did buy the tractor used but it was in great condition and I have not had any issues at all. I have ordered a new water neck with a new thermostat that should be here tomorrow, then we will see if that is the problem. I have been told there is a way to bleed air from the cooling system but I have not been able to locate it. Any suggestions?
