temperatur gauge
   / temperatur gauge #1
hogrider
Locust Fork, Alabama
2000 John Deere 4300
:anyone:I have a 2000 JD 4300 tractor. The temperature gauge goes from reading normal to past red mark; and later back to normal. I have cleaned radiator, air filter, replace temperature sensor and thermostat; replaced all 3 hoses , and cleaned instrument panel. No steam or boil over; coolant remains at same level when I started out. There is no coolant in reservoir. Can I damage my engine if I continue to operate tractor. Any help would be greatly appreciated. Owned/operated tractor for 9 years. Still learning Thanks
   / temperatur gauge #2
The reservoir should be between the marks when cold and the radiator full to the top when cold. Are you saying you are losing coolant every time you run it?
   / temperatur gauge
As far as I know, there has never been any coolant in it.
   / temperatur gauge #4
As I understand, there should always be some coolant in the reservoir. Give that a try... just as txranger suggested in reply 2
   / temperatur gauge #5
+1
Inspect the pressure cap when the engine is cold. Look for defects in the rubber seal or elsewhere.
Are you using JD 'Coolgard' Pre-Mix, some other brand or just plain water in your radiator?
Yes, you must have coolant in the reservoir - so your cooling system can expand & contract as necessary.
Yes, you can damage your engine by not knowing the state of the coolant in your radiator. Why do you think the engineers went to so much trouble to design, manufacture and install a reservoir bottle connected to the radiator with a hollow rubber tube and a sophisticated two-way pressure cap?
Why would you not bother to add coolant to the empty bottle?
Hopefully you don't have an internal issue causing coolant loss. You have a new sensor... The gauge itself could be faulty. An infra-red thermometer could be used to monitor the temp at the radiator top tank compared to the gauge indication.
4200/4300's were nice tractors in their day.
Regards,
:wrench:
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
Soosan 140 Hammer 30 ton Class (A52384)
Soosan 140 Hammer...
