temp guage
   / temp guage #1
skeeballhead
I have an 01 TC40 shuttle shift, etc. I want to add an OEM temp guage my dash panel. Has anyone done it? Or do I have to do an aftermarket type guage? Any help would be great, because I am sure the local New Holland guy would think I was high.
   / temp guage #2
I think you will have a lot more success at much lower cost by going to an aftermarket sender and gauge. Your temperature sensor on the engine is a switch, not a temperature sending unit (a resistor that varies with temperature). Also, the wire going to your instrument panel is wired to a light, not the upper right area where the temperature gage is mounted on the Deluxe model. If you pay the price of a complete instrument panel, you have no way of knowing if the wiring harness on the tractor will match your new instrument panel. You'd have to do a wire-by-wire check of the schematic and you'd surely have to add a wire for the sending unit or rewire your harness for the light wire to be used as the temperature gage wire.
Can you see how complex this is getting? I think I would look for an aftermarket gage that you cold mount somewhere convenient. You could cut a hole in the cowling below the instrument panel (the black one) and mount the gage there in a very professional and neat way.
Finally, I think if I were in your situation, I'd just buy an inexpensive IR thermometer to carry with me on the tractor. When I want to check temperature, I'd stop and do it with the IR. By doing it that way, you can use the IR for hydraulic temperature as well. It's very flexible and will leave your tractor without modification.
   / temp guage
Thanks Jinman, I just wasn't sure if anyone had attempted yet. I like to try and keep things OEM if possible. Anyway, thanks for the response, I do appreciate it.
Ford 18in. Stock Rims (A53117)
Ford 18in. Stock...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2005 International 8600 Hydro Vac Truck (A53117)
2005 International...
2009 Ford F-350 4x4 Flatbed Truck (A51691)
2009 Ford F-350...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53473)
2022 NEW HOLLAND...
