Oil & Fuel Temp and Fuel Gauges not working
   / Temp and Fuel Gauges not working #1
dennisB
Huntsville Alabama
Rural King RK24
I have been using YM2202D and it seems that the gauges are not working. Everything else works fine but the gauges do not turn on. They act like I have turned off the key but kept the tractor running. Would this be an indication of a bad ignition?
Thanks for any help and advice.
/forums/images/graemlins/confused.gif
   / Temp and Fuel Gauges not working #2
Are you saying that the gauges don't work at all ? If they are electrical gauges, I would check for bad fuse.
   / Temp and Fuel Gauges not working #3
check out the fuse connection at the bus box. My Ym2620d does the same thing every so often. Moisture and or dust get between the fuse and holder and acts as an insulator.
Dick
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
2803 (A50460)
2803 (A50460)
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
Tandem Axle Rear...
