Tell me about the 4510
   / Tell me about the 4510 #1
offroadr
Bronze Member
Central IL
JD 3320
I saw a JD 4510 at a local dealership today. I am not familar with this model. They were closed so I could not find anything about it. It had a FEL and a belly mower.
What year and HP would this be? What price range would be typical? It had 1100 hours and R4s. I think this a non hydro machine?
   / Tell me about the 4510 #2
2WD it is a 9x3 SyncShift
4WD it is a 12x12 PowerReverser
Engine
Manufacturer Yanmar
Engine Model Number (4510 & 4610) 4TNE84 (4 Cyl. 84mm bore...)
Gross Horsepower (4510) 28.6 kW (38.4 hp)
Manufacturer's Estimated PTO Horsepower (4510) 24.6 kW (33 hp)
Rated Engine Speed 2600 rpm
Operating Range 1000 - 2810 rpm
Engine Torque @ Rated Speed (4510) 100 N·m (74 lb-ft)
Displacement (4510 & 4610) 2.0 L (122 cu in.)
Cylinders 4
Bore and Stroke (4510 & 4610) 84 x 90 mm (3.3 x 3.5 in.)
Fuel Delivery Direct Injection, Self Bleeding
Drive Train
Transmission (4510 & 4610 SyncShift Transmission) 9x3 SyncShift (2WD only)
Transmission (4510, 4610 & 4710 PowrReverser Transmission) 12x12 PowrReverser (4WD Only)
Capability for MFWD All Ranges
Rear Final Drive Type Planetary Gear
Differential Lock Mechanical
Brakes Type Wet Disk
Steering Power, Cylinder-Assisted
Main Clutch Disk Type (4510 & 4610 SyncShift Transmission) Single Stage Dry
Main Clutch Disk Type (4510, 4610 & 4710 PowrReverser Transmission) Multiple Stage Wet
Main Clutch Disk Diameter (SyncShift & PowrReverser Transmissions) 24 cm (9.45 in.)
Front Axle Operating Capacity 450-500 kg (992-1102 lb)
Rear Axle Operating Capacity 900-1000 kg (1984-2205 lb)
Drawbar Tongue Capacity 259 kg (570 lb)
Hydraulic System
Type of System Open Center
Power Steering Standard
Implement and Steering Pump Type Gear Pump
Working Pressure 17237 kPa (2500 psi)
Pump Capacity (Main) @ Rated Speed 40.0 L/min (10.6 gpm)
Pump Capacity (Power Steering) @ Rated Speed 20.0 L/min (5.3 gpm)
Total Flow of Pumps @ Rated Speed 60.0 L/min (15.9 gpm)
3-Point Hitch
Type Category 1
Lift Capacity (24-in. behind link arms) 1135 kg (2500 lb)
Dimension - Lower Link Ball Socket ID 22 mm (7/8 in.)
Dimension - Upper Link Pin Hole ID 19 mm (3/4 in.)
Dimension - Normal Width @ Lower Hitch Pins 68.6 cm (27 in.)
Dimension - Normal Height From Center Pin to Hitch Pin 45.7 cm (18 in.)
PTO
Type Independent
Clutch Type Wet Disk
Brake Type Wet Disk
Speed (Mid PTO rpm @ Rated Engine Speed) 2100 rpm
Speed (Rear PTO rpm @ Rated Engine Speed) 540 rpm
Fluid Capacities
Fuel Tank 47.5 L (12.5 gal)
Cooling System (4510) 6.1 L (1.6 gal.)
Cooling System (4610 & 4710) 6.4 L (1.7 gal.)
Crankcase w/ Filter 4.8 L (5.1 qt.)
Transmission and Hydraulic System (Gear Models) 36.9 L (9.7 gal.)
Transmission and Hydraulic System (Hydrostatic Models) 35.0 L (9.2 gal.)
Front Axle (MFWD Models) 5.0 L (1.3 gal.)
Ground Speeds
4510 SyncShift Transmission with 13.6-24 Rear Tires
Range A - Gear 1 1.4 km/h (.9 mph)
Range A - Gear 2 2.0 km/h (1.2 mph)
Range A - Gear 3 2.7 km/h (1.7 mph)
Range B - Gear 1 4.8 km/h (3.0 mph)
Range B - Gear 2 6.7 km/h (4.1 mph)
Range B - Gear 3 9.0 km/h (5.6 mph)
Range C - Gear 1 12.4 km/h (7.7 mph)
Range C - Gear 2 17.2 km/h (10.7 mph)
Range C - Gear 3 23.3 km/h (14.5 mph)
Range A - Reverse Gear 1 1.6 km/h (1.0 mph)
Range B - Reverse Gear 2 5.9 km/h (3.4 mph)
Range C - Reverse Gear 3 14.3 km/h (8.9 mph)
4510 PowrReverser Transmission and 13.6-24 Rear Tires
Range A - Gear 1 1.4 km/h (0.9 mph)
Range A - Gear 3 2.5 km/h (1.6 mph)
Range A - Gear 4 3.5 km/h (2.2 mph)
Range B - Gear 1 3.5 km/h (2.2 mph)
Range B - Gear 2 4.9 km/h (3.0 mph)
Range B - Gear 3 6.2 km/h (3.9 mph)
Range B - Gear 4 8.6 km/h (5.3 mph)
Range C - Gear 1 10.4 km/h (6.5 mph)
Range C - Gear 2 15.5 km/h (9.0 mph)
Range C - Gear 3 18.5 km/h (11.5 mph)
Range C - Gear 4 25.6 km/h (15.9 mph)
Front Wheels and Tires
Available All Models w/ MFWD
8.00-16 6PR R1 TI
27x10.5-15 4PR R3 TI
10.00-16.5 6PR R4 TI
27x12LL-15 6PR GOLF GA
7.00-16 6PR R1 TI
Available Model 4510-4710 w/ 2WD
6.00-16 6PR F2 TI
Available Model 4610-4710 w/ 2WD
6.50-16 6PR F2 TI
Rear Wheels and Tires
44x18.00-20 4PR R3 TI
17.5L-24 8PR R4 TI
22.5LL-16.1 6PR Golf GA
13.6-24 6PR R1 TI
Available Model 4510 and 4610
14.9-24 4PR R1 TI
Dimensions
Wheelbase 1,8 m (71.5 in.)
Overall Length w/ 3-Point Hitch 3,4 m (135 in.)
Overall Width w/ R1 Tires (Minimum) 1,6 m (62 in.)
Overall Width w/ R1 Tires (Maximum) 2,3 m (91.1 in.)
Overall Width w/ R3 Tires (Minimum) 1,7 m (71.5 in.)
Overall Width w/ R3 Tires (Maximum) 1,9 m (74.4 in.)
Overall Width w/ R4 Tires (Minimum) 1,7 m (71.5 in.)
Overall Width w/ R4 Tires (Maximum) 2,4 m (92.6 in.)
Overall Width w/ Golf Tires (Minimum) 2,1 m (82 in.)
Overall Width w/ Golf Tires (Maximum) 1,9 m (74.4 in.)
Inside Width w/ R1 Tires (Minimum) 8,6 m (34.2 in.)
Inside Width w/ R1 Tires (Maximum) 1,5 m (60 in.)
Inside Width w/ R3 Tires (Minimum) 9,3 m (37 in.)
Inside Width w/ R3 Tires (Maximum) 1,2 m (48.2 in.)
Inside Width w/ R4 Tires (Minimum) 8,6 m (34.2 in.)
Inside Width w/ R4 Tires (Maximum) 148.6 cm (58.5 in.)
Inside Width w/ Golf Tires (Minimum) 1,5 m (37 in.)
Inside Width w/ Golf Tires (Maximum) 1,1 m (40.5 in.)
Height From Ground (4510 - 2WD)
To Top of Hood 1,3 m (51 in.)
To Top of Standard ROPS 2,3 m (91.4 in.)
To Top of Folding ROPS 2,5 m (97.4 in.)
Height From Ground (4510 - MFWD)
To Top of Standard ROPS 2,3 m (91.6 in.)
To Top of Folding ROPS 2,4 m (97.6 in.)
Minimum Front Tire Inflation Pressures (Unloaded/Unballasted Tractor)
6.00-16 6PR F2 TI 207 kPa (30 psi)
6.50-16 6PR F2 TI 165 kPa (24 psi)
7.00-16 6PR R1 TI 138 kPa (20 psi)
8.00-16 6PR R1 TI 90 kPa (13 psi)
27x10.5-15 4PR R3 83 kPa (12 psi)
10.00-16.5 6PR R4 TI 103 kPa (15 psi)
27x12LL-15 6PR GOLF GA 69 kPa (10 psi)
Maximum Recommended Front Tire Inflation Pressures
6.00-16 6PR F2 TI 359 kPa (52 psi)
6.50-16 6PR F2 TI 331 kPa (48 psi)
7.00-16 6PR R1 TI 248 kPa (36 psi)
8.00-16 6PR R1 TI 193 kPa (28 psi)
27x10.5-15 4PR R3 207 kPa (30 psi)
10.00-16.5 6PR R4 TI 310 kPa (45 psi)
27x12LL-15 6PR GOLF GA 221 kPa (32 psi)
Minimum Rear Tire Inflation Pressures (Unloaded/Unballasted Tractor)
13.6-24 6PR R1 TI 97 kPa (14 psi)
13.6-28 4PR R1 TI 97 kPa (14 psi)
14.9-24 4PR R1 TI 83 kPa (12 psi)
16.9-24 6PR R1 TI 83 kPa (12 psi)
44x18.00-20 4PR R3 TI 83 kPa (12 psi)
17.5L-24 8PR R4 TI 138 kPa (20 psi)
22.5LL-16.1 6PR GOLF GA 34 kPa (5 psi)
Maximum Recommended Rear Tire Inflation Pressures
13.6-24 6PR R1 TI 152 kPa (22 psi)
16.9-24 6PR R1 TI 124 kPa (18 psi)
44x18.00-20 4PR R3 TI 138 kPa (20 psi)
17.5L-24 8PR R4 TI 179 kPa (26 psi)
22.5LL-16.1 6PR GOLF GA 124 kPa (18 psi)
Weight
All Models 1564kg (3450 lb)
Recommended Lubricants
Engine Oil John Deere Plus-50® SAE15W-40 or TORQ-GARD SUPREME® SAE5W-30
Grease John Deere Multi-Purpose SD Polyurea Grease
John Deere Multi-Purpose HD Lithium Complex Grease
John Deere Moly High Temperature EP Grease
Transmission Oil Low Viscosity HY-GARD® (JDM J20D)
Front Axle Gear Oil Low Viscosity HY-GARD® (JDM J20D)
(Specifications and design subject to change without notice.)
Thanks for the specs, looks like it might be more tractor than I need. Looks like 18-20k is the norm.
2025 96in Fork Extensions (A42742)
2025 96in Fork...
23" Excavator Bucket (A42021)
23" Excavator...
2019 LANDOLL CORPORATION 455B TRAILER (A45333)
2019 LANDOLL...
2020 MACK PINNACLE P164T (A45046)
2020 MACK PINNACLE...
2005 MACK CT713 PUMP TRUCK (A45333)
2005 MACK CT713...
SWEEPER ATTACHMENT (A45046)
SWEEPER ATTACHMENT...
