telescoping lower links stink!
  • Thread starter kingoflawns
  • Start date
   / telescoping lower links stink! #1
K
kingoflawns
Guest
I really dont like them! Not only do they cause a hardware conflict (pins mashing) with my landpride quick hitch,they just dont seem to work well. Perhaps its just me because im a knucklehead, wouldnt be the first time.
   / telescoping lower links stink! #2
<font color="blue">
I really dont like them! </font>
I bet there are thousands of B7800 owners out there that would be willing to swap their fixed lower arms for your extendable ones! /forums/images/graemlins/shocked.gif
Heck, I'd be willing to buy some replacement fixed links for you, if you would send me the original telescoping parts in return!
Let me know... /forums/images/graemlins/smile.gif Only offering because I would like to make YOU happy! /forums/images/graemlins/grin.gif (I think I could adapt them to my BX...)
This coming from henro (one of the most respected people on tbn) confirms my fears, i am a knucklehead, bummer! /forums/images/graemlins/crazy.gif
   / telescoping lower links stink! #4
I love them. I had to learn to operate them first though and no fancy quick hitch to make trouble.
   / telescoping lower links stink! #5
</font><font color="blue" class="small">( This coming from henro (one of the most respected people on tbn) confirms my fears, i am a knucklehead, bummer! /forums/images/graemlins/crazy.gif )</font>
Ha Ha! LMAO! Funny.
   / telescoping lower links stink! #6
What's not to like? I learned to hook up 3PTH implements on old Fords when I was a kid so the lower links on my B3030 are just too easy. I think that cab has spoiled you and made you soft in your old age. (just kidding) /forums/images/graemlins/grin.gif /forums/images/graemlins/cool.gif
Is the trick to just slide them back a half inch or so, then back up ? I seem to get one locked back in, the other locked out, and several times had to fully disconnect & rehitch without using them. Its frustrating!
   / telescoping lower links stink! #8
I'm with you ToolGuy, I think the telescoping lower links are better than Peanut Butter! /forums/images/graemlins/grin.gif
Try and take mine and you're in for a fight.
   / telescoping lower links stink! #9
Yes, the trick is to not pull them out all the way. If the weight of the arms themselves are pushing down on the ends when they are all the way out they do not like to go back in. I try to mount an implement by first adjusting the width of the lower links with the adjustable swaybars so that they are wider than the pins on the implement. I then back up as squarely as I can to the implement and, using the postion control lever, get one arm close to one of the pins on the implement. Use the telescoping feature to connect the closest pin. Then do the other side. If you can get close enough so that you don't have to fully extend the arms it makes it a lot easier. The telescoping feature helps with that last inch or so. Then just back up or wiggle the implement until the arms are locked in. Not as easy as a quick hitch, but not to difficult either. Good luck.
   / telescoping lower links stink! #10
My ford 5000 has telescoping links.. my NH 7610s doesn't. Wanna bet which one is an easier hookup when i hitch the 2500# 3pt 10' mower...
Soundguy
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2014 Nissan Pathfinder SUV (A53117)
2014 Nissan...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2013 International Terra star (A53422)
2013 International...
