telescoping draft links
   / telescoping draft links #1
jpig
Tennessee
jd 5205
I need some input on the John Deere telescoping draft links.
Are they worth the money and do they save time and your back?
   / telescoping draft links #2
If you're referring to telescoping lower links on the 3PH, I don't know what they cost, but would bet they're worth the money. They do save time and your back, not to mention frustration. /forums/images/graemlins/confused.gif
   / telescoping draft links #3
I have the telescoping links on my 4310 and find them to be most helpful.
When I purchased the tractor I had them add an I-Match, but there have been a couple implements that aren't compatible and I had to remove the I-Match. When that happened, the telescoping links were "worth their weight in gold" (well not really at the cost of gold, but that is the old saying).
How much extra are they? I didn't even look at the package without.
   / telescoping draft links #4
</font><font color="blue" class="small">( Are they worth the money and do they save time and your back? )</font>
Yes, Yes and YES (in that order!) /forums/images/graemlins/grin.gif
   / telescoping draft links #5
Yes. My tractor already had them installed sitting on the dealer lot. I bought an I-Match, but it turns out the only implement it fits is my LX-6. I'm thinking about taking the I-Match back for a refund.
Anyway, I took the I-Match off and the telescoping links made life real easy hooking up my harrow and box scrape. I'm going to look into some other quick attach products that have been mentioned here on TBN. There are probably certain implements that no quick hitch will work on, so the telescoping links are definately worth having.
   / telescoping draft links #6
I was told by my JD dealer that the telescoping links are on most of their 5XXX series tractors, but is not available in the 4X20 series. What's up with that?! /forums/images/graemlins/confused.gif I think they are rather handy myself.
   / telescoping draft links #7
</font><font color="blue" class="small">( <font color="blue"> When I purchased the tractor I had them add an I-Match, but there have been a couple implements that aren't compatible and I had to remove the I-Match. When that happened, the telescoping links were "worth their weight in gold" (well not really at the cost of gold, but that is the old saying). </font> )</font>
I agree exactly, same experience here.
   / telescoping draft links #8
Every 4520 I've seen, including mine, have the telescoping links.
Thanks everyone for your replys. I think you have talked me into getting the telescoping links. Anyone want sell a set?
   / telescoping draft links #10
</font><font color="blue" class="small">( Every 4520 I've seen, including mine, have the telescoping links. )</font>
Really? I wonder why when ordering a new 4720 cab model, the telescoping arms are shown as "N/A"? /forums/images/graemlins/confused.gif When I asked, my JD dealer simply said that they were not available on the 4X20 lineup.
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
2019 DODGE RAM 3500 (A52472)
2019 DODGE RAM...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
2004 FORD E350 MECHANICS TRUCK (A52576)
2004 FORD E350...
