Teflon Tape
   / Teflon Tape #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
Is teflon tape diesel safe? I need to put a nipple between a filter and a pump and am not sure how to seal the connection. Gaskets would probably be allright too but I imagine that would also have to be the right kind.
The connections are 3/4" NPT.
Thanks.
   / Teflon Tape #2
Teflon tape is not effected by diesel fuel, but if a piece of it gets loose, it will not pass through the diesel pump or injector. Personally, I wouldn't use it, but would rather use a good quality pipe dope and only use enough to get into the threads. When in doubt, use less ........ you can always add more. As I have said in the past, Teflon tape is for old worn threads and pipe dope is for new threads. Use the correct sealant and you will have a better chance of success. Also, pipe threads are tapered...... the more you turn them in, the tighter that they get....... at a certain point, you will crack the casting that you are screwing into. I have seen plumbers do this with Teflon tape on a new installation when Teflon tape first came out. I rarely use it any more..... pipe dope is better and it is approved for most gas, gaseous, and liquid applications....
   / Teflon Tape #3
I use Perma-tex (aircraft sealant) on all connections that have fluid in them. Takes sometime to "dry" but it works. Good for all types of fluids, heat etc
   / Teflon Tape #4
It's all in what you are putting together. Don't use it on any of your hydraulic connections. I will cause problem there. Just use pipe dope.
   / Teflon Tape #5
We use a hydraulic/pneumatic sealant on all of our stuff. Most manufacturers I deal with will void warranty if they find teflon tape. The brand we use is Loctite part number 545.
If you went to any real auto parts store they will have a catalog, or Permatex also makes that product.
   / Teflon Tape
Dope it is. Thanks.
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
