tedder
   / tedder #1
jd2210
Ontario
2210 JD
I'm getting sick and tired of watching my hay get ruined while I wait for it to dry. My cousin does custom baling and swears by a tedder. Does anyone out there use a tedder on heavy alfalfa or red clover? what is your typical drying time? Do you like the one you have, and how much do they cost?
I've looked at Krone and some Italian pile of junk and man are there differences in quality. I guess that's why one was $8500 and one was $1500
   / tedder #2
They may help a little but I really think they are over rated. For the cost of a tedder I would put a preservative system on your baler. You aren't going to cut your hay much more than a half a day sooner. With preservative you can get a good day and even up to two days. Plus with alfalfa it is really hard on the leaves to ted it even when the hay is still wet.
   / tedder #3
I don't know how you can make hay without one, its hardly possible in our area. (Atlantic Canada)
The usual proceedure is cut in morning with a mower conditioner, let the ground dry out, ted the next morning, if an exceptionally hot dry spell you can bale that night, otherwise it stays to be raked the next morning and baled that afternoon.
Things to speed up the process, Cowboydoc has a good suggestion with the acid sprayer. I read there are now custom operators with macerators in Canada but those are very $$$ and lose some leaves. Not much else you can do from my understanding of alfa-alfa being sensitive. Balage or silage is common here.
For grass crops the non rubber roller mower conditioners are supposed to knock a day off but they would knock the alfa-alfa to pieces from what I read.
If you want to try tedding on a small scale to see what it can do for ya, see if a dealer will loan you a used tedder to try on a small area. Most dealers here will do that for people.
Ken
   / tedder #4
Ken, I guess it depends on the climate, type of hay, etc., but anyway, I've never used a tedder and never even seen one in use. The neighbor I had whose full time business was hay had one (I had to ask him what it was the first time I saw it), but said he very rarely used it; only when he had to, and that it knocked a lot of the good leaves off the hay so you wound up with poorer quality hay when you had to use it.
   / tedder #5
jd2210,
It is just like in auto's, there are many different models that provide the same operation. The Italians have lighter and heavier duty units. The Germans and French usually purchase their medium and lighter duty tedders from the Italians and MFG the heavy duty units for their upscale markets. We sell tedders priced from $500-$10,000.
   / tedder #6
I wouldn't be without one here in the south where the hay is usually so thick by the time we get the first cutting it won't dry without one. Mine is a Sitrex. I bought it new 4 years ago and have used it for about 30,000 sqaures and a few hundred rolls. No problems at all. I agree it is hard on leafy hay like alfalfa, but for fescue, orchard grass, etc theycan't be beat.
   / tedder
thanks guys. I have a very unpredictable climate so this may be the answer for me. I don't like feeding black bales very much.
   / tedder #9
James,
Before you spend alot and are disappointed most of the guys that posted on the positive side for a tedder were talking about grass hay. On grass hay it does help but on clover and alfalfa it has ruined as much quality in our hay as it has saved us. It's like night and day doing hay that is alfalfa compared to grass. Besides 5030 on this board anyway I don't know anyone else that does much alfalfa.
   / tedder
thanks for the warning. It actually was the main reason for my post in the first place. We do mostly alfalfa and clover so I may need to rethink. Maybe I'll just break down and wrap some bales. But that is such a pain, and we make 2000, 1800lb bales a year so that would cost $6000 in plastic alone. /forums/images/graemlins/frown.gif
City of Buckhannon - 2005 Volvo Garbage Truck (A52384)
City of Buckhannon...
2000 HONDA FOURTRAX 300 ATV (A51247)
2000 HONDA...
2017 GENIE S-60X MANLIFT (A51246)
2017 GENIE S-60X...
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A51247)
UNUSED INDUSTRIAS...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
