Techniques to picking up gravel w/ FEL ?
   / Techniques to picking up gravel w/ FEL ? #1
bcarwell
Austin, Texas
Kabota 7500DT
Hi all,
I have a Kubota 7500 (23HP) with a FEL. I also have several piles of gravel that are about 1/2 inch rocks. The piles are maybe 5 feet wide and 5 feet tall.
I need to move them out of sight. My FEL has no teeth and I don't have time to buy any attachments- gotta make do with what I got.
The question is: do you have any techniques for getting the most gravel in the bucket each time you attack the pile ? In the past in trying to move gravel, I just don't quite have the technique down. I end up pushing alot of the pile over and spreading it out, and having to shovel gravel into the bucket.
I've tried "charging" the pile at mid-heighth and trying to "jiggle" or tilt the bucket upwards as I continue moving into the pile. I've tried moving into the pile with the lower lip of the FEL bucket parallel to the ground and at ground level, e.g. moving into the very bottom of the pile. But I still end up pushing alot of the pile all over the ground. Maybe take a little bite off the top and jiggle, then back out and do it again ? It seems like maybe I don't have enough momentum with a compact tractor, or I'm afraid to really "charge" the pile.
Any technique suggestions or tricks ? Backdragging onto a flat 4x8 sheet of plywood ? Or trying to use the plywood somehow vertically as a back stop if I could imobilize it. Getting my wife to shovel instead of me ? Throwing topsoil on the piles and planting nasturtiums ? Offering the piles for free on Craig's list (I have no use for them).
Bob
Bob
   / Techniques to picking up gravel w/ FEL ? #2
Tilt back and raise loader at the same time as you go into the pile.
Like your slicing the front of the stack off from the bottom to the top while tilting the bucket back.
   / Techniques to picking up gravel w/ FEL ? #3
I've not had much luck "charging the pile"; my tractor does not have enough ooomph. What has worked the best for me is to drive up to the gravel pile with the bucket bottom parallel with the ground and maybe a foot or so off the ground then drive forward into the pile while curling the bucket. It almost causes a little avalanche of gravel that fills the FEL.
I am still anxiously waiting for the toothbar to get here though.
   / Techniques to picking up gravel w/ FEL ? #4
I hate to tell you this, but without a toothbar, it's going to be tough.
However, put several hundred pounds of ballast on the 3PH. That's a must!
If the gravel is clumpy from setting around, use a pick and break into it enough to get the full width up your bucket into it. Once you get through the clumped together outer layer, the inside of the pile might be looser...maybe.
I never had much luck moving gravel (only had to do it once) until I got my ballast box (500-600 pounds). Even with a toothbar, my 790 would set and spin...and that's a tractor weighing considerably more then your B7500. It did work well when I added the ballast, however.
BTW, this stuff had been setting around almost a year and was really clumpy.
If all else fails, shovel it into the bucket... Keep that bucket low when you're moving it!
Good luck!
   / Techniques to picking up gravel w/ FEL ? #5
Roy is right. Without a lot of ballast, a FEL is useless.
I used my FEL for a few months with only a box blade and 240# of suitcase weights hanging on the edges for ballast. It worked good, or so I thought. I eventually added a backhoe. NOW the FEL's capability was apparent and the overall stability was dramatically better.
A pile of gravel will stop your tractor and let its tires spin unless you have enough weight on the back to increase the traction. It would be very hard to put too much ballast on the back.
Just as the bucket is ready to go into the pile, tilt it down about 30 degrees from level. Jab it into the pile and then curl it up in one smooth motion as you raise the bucket at the same time while inching forward about 6-8" With a little practice you can fill the bucket full. Keep it tilted back to keep all the gravel in it and then lower the arms close to the ground asap once you back away from the pile. Always cary a full bucket as close to the ground as possible.
If you try to carry 500# 5-6' up in the air with a small tractor and you hit a 5" pothole with a front tire, you will have an interesting ride. Try carrying that same load 6-8' up in the air and when you hit that pothole, you can then call your tractor buddies to come help you pick up your tractor from its side.
   / Techniques to picking up gravel w/ FEL ? #6
On my 4010 with a 53" bucket, I need about 300-400# of ballast on the back.
With bucket level, curl it a bit as you touch into the pile and drive forward and then lift lift up, all at the same time; they're all rather slight movements; don't get too rough on the controls in either of these. If you end up a little short, just level the bucket, lower it and try again. I've raised if fairly high and jiggled it a bit to shake the gravel to the back of the bucket before trying again. Just make sure you have plenty of ballast! Best thing would be a box on the carryall and a load of gravel in it to start. Need loaded rear tires, too.
I hauled about 20 tons of gravel along a trail that runs across my hill and through the woods behind my house and am hauling mulch a fair bit down to the garden. The technique of loading the bucket is about the same in both mulch and gravel.
Ralph
   / Techniques to picking up gravel w/ FEL ? #7
RoyJackson said:
1*I hate to tell you this, but without a toothbar, it's going to be tough.
2*However, put several hundred pounds of ballast on the 3PH. That's a must!
3*If the gravel is clumpy from setting around, use a pick and break into it enough to get the full width of your bucket into it. Once you get through the clumped together outer layer, the inside of the pile might be looser...maybe.
4*I never had much luck moving gravel (only had to do it once) until I got my ballast box (500-600 pounds). Even with a toothbar, my 790 would set and spin...and that's a tractor weighing considerably more then your B7500. It did work well when I added the ballast, however.
5*If all else fails, shovel it into the bucket...
6*Keep that bucket low when you're moving it!Good luck!
1*I've never had any problem without a tooth bar on my Kubota BX23.
However the tillers on the old bolens and the new CC 2554 plus the BH on the bx23 make pretty good tooth bars.
2*The BH is all the ballast I need on the bx23.
3* I use the BH. It makes a great pick. For dirt I use one of the tillers or the BH.
4*I've moved quite a bit of gravel and slag with the BX23 with no problems.
5*My shovels for doing something like that is the front blade on the old bolens or the front blade on the CC2554. Just lower the FEL bucket level with the ground and shove the gravel into the bucket with the Bolens or the CC 2554.
6*Absoulety
   / Techniques to picking up gravel w/ FEL ? #8
I can load gravel into the BX23 fel bucket.
No tooth bar = no problem.
   / Techniques to picking up gravel w/ FEL ? #9
The problem with rocks and no teeth is that the wide area of your bucket blade is distributing the force of the tractor across the entire area of the rock pile. Kind of like why snowshoes keep you walking on top of the snow, rather than sinking in. Putting teeth on a bucket is like taking off your snowshoes... it allows you to sink into it.
Unfortunately, rocks is one of those things that is hard to dig into without teeth. Anyhow, here's the technique I use, wether I am using my small rock bucket with teeth or my large, light material bucket without teeth. The technique is the same for both and comes from an International Harvestor industrial loader operator's manual from the late 70's.
Keep the bucket parallel to the ground.
Drop it to the ground and then curl it back about an inch so the leading edge doesn't dig into the ground.
In your lowest range and gear, drive into the pile (Do not "charge at the pile").
As the tractor slows, keep driving forward as you slowly curl the bucket back and lift at the same time. This will cause the material above the bucket to fall into it and the pressure of lifting and curling will "crowd" the bucket full of material for you.
After a few tries, you will get the feel of what works best for the material that you are loading.
   / Techniques to picking up gravel w/ FEL ? #10
bcarwell said:
Hi all,
Bob
I sure could use free gravel . Just load them up in your tractor and bring them over here to me.
Oh I forgot you're having trouble getting the gravel into the FEL bucket.
safety baskets (A53421)
safety baskets...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2019 JOHN DEERE 325G SKID STEER (A52706)
2019 JOHN DEERE...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
