tech info on 390 MF
   / tech info on 390 MF #1
mihdogg
hi all,my farmily own quite a bit of land in the in one of the small CarribeanIsland called Trinidad,i live in the Uk,one of my relative has just bought a 390 MF tractor,he does small farming and because of inavailability of tech Knowhow and attachments for the tractor i have been asked to help, i am a diesel fitter by profession and now work as an Engineer on high speed Trains,so here i go,Tractors? dont know ,iam asked to find attachments such as Ploughs ,Rotavitors grass cutter and **** knows! i got no spec on the 390 machine as to engine type and Hp ratings to make the right choice as to what bits and what to look for so any help would be much appreciated so thank you all out there hope to hear from you all soon
   / tech info on 390 MF #2
The MF390 was built from 1986-1998. The tractor has 75PTO hp. This means you could pull a 8ft or 10ft BushHog with it, and just about any piece of equipment you wanted to run. The dry weight is 6275lbs. 4 different transmissions were offered, and the diesel is made by Perkins. Let me know what the serial # is and I'll tell you what year it was made. Hope this helps some!
Thank you very much,thats an excellent start,i am waiting for the paper work that came with the tractor to be posted to me from back home will definitely let you know NICE ONE ! /forums/images/graemlins/cool.gif
(14) Round Alfalfa Bales (A50515)
(14) Round Alfalfa...
Deere 331G (A50120)
Deere 331G (A50120)
2006 International 9400i (A52748)
2006 International...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2015 Ford F-550 4x4 Knapheide Service Truck (A50323)
2015 Ford F-550...
10' Poly Feed Trough (A50515)
10' Poly Feed...
