hoogy JD
I have a MF gc2300. When i mowing lawn and turn a corner the inside tire is tearing up the lawn. What is causing this.
not in four wheel drive diff lock lever is in the up right poistion.tire tears lawn when turning. have heard a click when turning a few times but not all the time. tire spinning yes it seems to spin faster then outside tire
Lot's of rain here also. Tore my yard up pretty good while mowing yesterday.You have had a lot of rain and my guess is you are turning too sharp of a circle for conditions and the inside is simply turning faster than the outside. I've done it, or use to do it frequently. You are probably trying to turn a tight circle around a tree or something and the tractor is sliding and the tire is doing the damage. If that is the case you need to mow differently in damp conditions and make a series of "pull forward, back up, cut side, back up, cut other side, etc". That will work.
If I guessed incorrectly, try the other posts about 4WD, etc. Advise how you make out.
