Tearing out parquet flooring ---->question
   / Tearing out parquet flooring ---->question #1
Gitche Gumee Kid
Bronze Member
NW WI
IH 284
Due to buckling from last years extremely high humidity and also it's the original floor (installed 1982 ) so it's shop worn and due for a change.
Question. What's the easiest way to remove the mastic. I'm afraid you're going to say there is no easy way LOL.
Is the something that can be applied to aid the stripping process?
TIA
GGK
   / Tearing out parquet flooring ---->question #2
Check with your local flooring specialists...
   / Tearing out parquet flooring ---->question #3
Heat gun and a scraper. Best if someone gets on the floor aiming the gun and another uses a long handle floor scraper - easier on the back and goes a little faster. You need lots of patience. Good luck. KW
   / Tearing out parquet flooring ---->question #4
If the heat gun doesn't work go the other way and use dry ice. I once had a job removing tiles and the heat gun would only soften portions of the tile at one time so the tiles came up in pieces. A real mess. When I switched to a large block of dry ice and a floor scraper the tiles popped up whole like large poker chips. As KW mentioned a truckload of patience will be required.
SimS
   / Tearing out parquet flooring ---->question #5
It should be on some kind of underlayment and not directly on the subfloor. Hopefully the underlayment wasn't glued. I'd take a circular saw set to the right depth to cut the underlayment but not subfloor, then take up the underlayment and parquet together in squares.
If it's not badly buckled and height is not an issue, leave the parquet and go over it with new underlayment.
Finally you could use one of the aggressive style hardwood floor refinishers. They'll tear through about 1/8" of floor at a time but it will get really wavy if you aren't careful, then you'll have a different problem to solve.
   / Tearing out parquet flooring ---->question #6
Use a roofing removal shovel. I sort of looks like a square garden spade but has a wedge so that you can lever the tiles (roofing) off.
Depending on what kind of adhesive used you can also sometimes whack here and there with a sledge and tiles will loosen..
   / Tearing out parquet flooring ---->question #7
What is under the parquet?
I had carpet that was glued to a concrete floor. When I took up the carpet the glue stayed behind. I rented a floor sander and was able to get it up without disturbing the concrete.
<---------------------------------------------------------0------------------------------------------------>
Concrete . My entire home is on a slab built over a hollow space. Actually a plenum for the infloor heating (hot air )system.
GGK
   / Tearing out parquet flooring ---->question #9
Rent a vibrating tile remover. It is heavy.and has a flat scraper blade that moves back and forth parallel with the floor. It will be much easier if it works for you like it worked for me.
2013 FORD EXPLORER (A54756)
2013 FORD EXPLORER...
201930 (A54756)
201930 (A54756)
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A55218)
2022 Gravely...
2023 Country Clipper Boulevard 54in Zero Turn Commercial Mower (A52377)
2023 Country...
2025 GM670 Compact Track Loader Skid Steer (A53421)
2025 GM670 Compact...
