I recently changed the oil seal in the crankshaft due to a leak. While the tractor was split, the clutch was changed out as well. The old clutch worked perfectly though.
Now I am having big worries as the clutch seems to not be engaged. Every time I am pushing the pedal down, there's noise from the clutch. The same noise appears when I have put the tractor in gear whatever clutch position. There's also a struggle to change gear, as it's seems that the spin of the axels are not in sync. The tractor does not stop when i put the clutch pedal down again. The only time there's no sound, is when it's in neutral with the pedal free.
I have tried to adjust the pedal shaft, but I cannot get the clutch to stop making this noise in any position of the shaft. I have also swapped PTO to have a 1 3/8" shaft, would this cause this problems?
I worry for having to split the tractor again for what's likely to be an adjustment at the fingers, am I wrong here?
