TC55DA
   / TC55DA #1
TC55DA/ Boomer
Tractor with turn over but not crank, fuel is not coming out at the injectors. Fuel filter has been changed.
   / TC55DA #2
There is a fuel shutoff solenoid on the backside of the injection pump. Either it is not working or there is a fuse for this circuit that has blown.
   / TC55DA #3
Not sure why you have 2 threads for the same issue but as I stated in your last post:
On the TC's the seat switch and the parking brake switch will not stop the engine from turning over but they will cause the fuel solenoid to shut off... so check both of those first.
The fuel solenoid is on the right side of the tractor on the same side as the ignition switch and down by the oil filter. If you set the parking brake and turn on the key, you should be able to hear it click.
If the fuel solenoid is not working & the engine cranks but will not start, it is most likely related to the seat switch or broken wire in the seat switch circuit or a bad fuel solenoid. It also could be the operator safety module, but I would check that last last after the seat switch wiring or bypass is verified good.
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A51243)
UNUSED INDUSTRIAS...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
**INOP** 2007 KOMATSU WA320-5L WHEEL LOADER (A51242)
**INOP** 2007...
Manac Walking Floor Trailer (A50322)
Manac Walking...
